Ont box date
Dixie2442
Ont box date
Anyone know how long to install the ont box I'm due to change over 9th Oct 2023 but heard nothing from openreach other than to say I confirm they can install it
9 REPLIES 9
Fixes: 118
Re: Ont box date
@Dixie2442
The ONT box is the easy part of an installation. Running the fibre and bring it into the house is the more time consuming element. You also have a box on the outside wall.
A straight forward install might take up to two hours but each is different.
Dixie2442
Re: Ont box date
How do I find out when they will put box on wall
ClaudiaG23
Fixes: 25
Re: Ont box date
Hi @Dixie2442  You'll get a confirmation email with the engineer appointment, the Suppliers will book the earliest slot available.
 Claudia Garner
Dixie2442
Re: Ont box date
Thanks I'm due to change over next wk only had email from openreach asking if I agree to the installation
Fixes: 1,495
Re: Ont box date
Moderators Note
This topic has been moved from Full Fibre to My Orders
Fixes: 118
Re: Ont box date
@Dixie2442
Use the following checker and see what it says.
Against WBC FTTP in the results window you're looking for "One Stage" to the right under install. Then, in the narrative below the window, it'll say something about the install. What matters is if it notes any potential problems.
If it's One Stage, then everything is done in one visit  - internal and external. As stated it can take less than two hours with no problems.
Dixie2442
Re: Ont box date
They ask for telephone DN etc I know none of these
Fixes: 118
Re: Ont box date
@Dixie2442
Use the Address version. Enter the Post Code only and select the address from the drop down list.
Dixie2442
Re: Ont box date
Many thanks for the help all sorted
