Order Status shows engineer visit complete but they didn't turn up
Nost1974
Waited in all day today for the install engineer but they didn't turn up.
Order tracker is showing a sucessfull visit.
Not impressed.
If my existing supplier ceased their service based on this I'll be far from impressed.
Can someone look into this ASAP please?
8 REPLIES 8
Fixes: 480
Re: Order Status shows engineer visit complete but they didn't turn up
Moderator's Note
This topic has been moved from Full Fibre to My Order
Nost1974
Thanks for moving the post. Any ideas on the response time to my question please?
Fixes: 117
@Nost1974
You should phone PN Support to get Help. Staff do monitor this forum but there's no guarentee when they'll pick up the thread.
nitram
What change was underway, was there an obvious reason for an engineer to visit the property?
'Engineer visit' has been known to mean 'engineer to visit exchange'.
Fixes: 480
@Nost1974 wrote:
....Any ideas on the response time to my question please?
Just in case that you are unaware, we Moderators are not Plusnet staff, we are fellow customers with no access to the Plusnet business system.
Nost1974
A full FTTP install so an engineer visit would be needed. I'm also not an existing customer.
Fixes: 579
Is it a 2 Stage install ?  If so,  the 1st visit is a survey/check to see what work is involved which would not require access to the premises. Openreach will then schedule the actual install date
corringham
Seasoned Champion
Fixes: 23
Were you advised that you needed to be available to allow access to your property, and/or that it was to actually do the install?
