Cancellation enquiry
- My Account/Billing
- Re: Cancellation enquiry
- « Previous
- 1
- 2
- Next »
05-02-2012 11:35 PM
I have changed the router as the Thomson one is a load of ......... and its a bit quicker...still only getting 3mb downloads and 300k upload speed with a 45m Ping... really slow service compared to what I am used to!
Looking to get out of Plusnet ASAP but think I have to wait until May.....unless you guys can sort out my speeds?!
Message 16 of 23
(630 Views)
06-02-2012 12:43 PM
Hi mmalh0151,
I'll certainly take a look for you.
Jojo
Jojo
Message 17 of 23
(630 Views)
06-02-2012 12:52 PM
Hi mmalh0151,
Your SNR is currently 16dB, so that will be causing your sync to be lower. How is your kit set up? Are you using any extension cables/sockets?
Jojo
Jojo
Message 18 of 23
(630 Views)
06-02-2012 1:02 PM
Hi, straight from the main master socket. Only a home phone and router connected to it, via microfilter of course
Message 19 of 23
(630 Views)
06-02-2012 1:19 PM
Do you have a test socket?
Message 20 of 23
(630 Views)
06-02-2012 1:28 PM
Just checked, no test socket and internet on laptops and iphones is getting very very slow... Almost 56k!
Message 21 of 23
(630 Views)
06-02-2012 5:13 PM
connections to iPhone and laptops will be wireless, so that's a totally different issue. How long has your set up been like that and when did the slow speeds start?
Message 22 of 23
(630 Views)
06-02-2012 6:42 PM
When i joined plusnet i noticed slower speeds but i didnt have an extra laptop or iphones at the time.
The new router works better as expected but it does hang sometimes
Message 23 of 23
(630 Views)
- « Previous
- 1
- 2
- Next »
