Tethering
- Mobile
- Tethering
Tethering
11-01-2020 8:17 AM
Re: Tethering
11-01-2020 8:31 AM
Assuming the phone is running Android?
Have you tried the suggestions in this thread https://community.plus.net/t5/Mobile/Tethering-doesn-t-work-on-unlocked-Lenovo-B-or-Huawei-Y300/m-p/...
Re: Tethering
11-01-2020 7:01 PM
Re: Tethering
11-01-2020 7:31 PM
Do you have any friend that might understand it and help you ?
I'm afraid that some phones seem to require that setting and others dont , my first phone required it but my latest worked fine straight away
Re: Tethering
13-01-2020 5:05 PM
Re: Tethering
13-01-2020 5:46 PM - edited 13-01-2020 5:46 PM
@Loobs39 you dont need to download the whole Android studio. On the download page , scroll down to the 'command line tools only' section. That's all you need and that download is much smaller
Re: Tethering
14-01-2020 11:19 AM
Re: Tethering
14-01-2020 11:51 AM
@Loobs39 Ok , Im sorry , it seems that the installation method for adb has changed significantly since I used it.
I have it installed on my Linux desktop but havent installed it on a Windows machine for some time.
When I get chance I'll try and get it installed on my Laptop and produce a set of detailed instructions for you.
Re: Tethering
14-01-2020 12:31 PM
@Loobs39 ok, I've now got it working on my Windows laptop
Delete that which you already have downloaded and copied to the laptop previously as part of attempting to install adb.
Then have a read through this guide https://www.xda-developers.com/install-adb-windows-macos-linux/
and if you feel confident then give it a go. That's what I've just followed to install on my laptop.
If you have any questions or are unsure of anything then post back with the queries
Re: Tethering
14-01-2020 12:58 PM
Re: Tethering
14-01-2020 1:17 PM
It needs to be downloaded to the laptop. I'd assumed you'd got broadband at home which the laptop could use for an internet connection. If that's not the case then we have a catch 22 situation.
On the earlier thread https://community.plus.net/t5/Mobile/Tethering-not-working/td-p/1615134 an app Clockworkmod tether was suggested as an alternative. That would be installed directly on the phone and wouldntninvolve so2nl9qding to the laptop. I've not used that myself and so have nomideabif it works
Re: Tethering
14-01-2020 1:57 PM
Re: Tethering
14-01-2020 2:09 PM
No problem. If you need any help when you get back then shout up.
