Buying another mobile number SIM
Solarpower03
Hi all
I already have an account and a mobile number with Plusnet. If I want to add another (and port) SIM, how the process works? Is another number added to my current Plusnet account and I will have two numbers/SIMs? Can I operate them individually and independently as required? How do I get bills- do I get one bill for each number or do I get a combined bill?
Solar
7 REPLIES 7
Fixes: 381
Re: Buying another mobile number SIM
Each SIM will have a different account and be managed completely independently of the other(s)
Solarpower03
Thanks- so with one email, I can have two Plusnet accounts?!
Fixes: 381
@Solarpower03  I dont think the email address is used for anything other than correspondence on a mobile account so I dont see why 2 accounts cant use the same email, although we would need a PN staffer to confirm that.
Fixes: 1,482
I have 3 mobile accounts using the same email address (and bank account), so it is definitely possible Smiley
abails0105
Fixes: 60
Hi @Solarpower03, thanks for getting in touch.
You can have more than one account with the same email address. Your bills for each account would be issued separately rather than just one big bill
Let us know if you need anything else
 Alice Baillie
Solarpower03
Thanks- ordered the second SIM today. I will port the number later. I am wondering when I am sent details for online account login?
adamwalker
Fixes: 220
Hi there, you should have been asked to set up a password as part of the process of signing up the account. You'd just need that and the mobile number of the SIM in order to log in. If you're unsure of the right password it can be reset here: https://www.plus.net/my-account/mobile/jsf/pages/ForgotPassword.xhtml - Adam
 Adam Walker
