Voyager 1040 Wireless Adapter - Setup Guide
Important - If you are installing this wireless adapter as part of an existing wireless network with a base unit (e.g. BT Voyager 2100), you should install and switch on the base unit before proceeding.
Do not plug in your BT Voyager Wireless Adapter until instructed to do so in this guide.
Software installation
Before installing your PCI expansion card, you should install the driver software.
1 Insert the BT Voyager Wireless CD into your computer's CD-ROM drive. The CD will automatically bring up a menu screen from where you can start the installation process.
2 To install, click Install BT Voyager Wireless Adapter and click Next when the installation wizard starts. You will be asked to read the Software License Agreement, you should continue by clicking Yes.
3 Next you will be asked to confirm where to install the driver files. If you are happy with the default directory, click Next.
4 When the driver files have finished copying, click Finish. You have now completed the software installation phase.
Hardware Installation
You are now ready to fit the Voyager 1040 PCI Adapter into your computer.
5 Ensure that your PC has been shutdown, unplug the power cable or switch off power at the mains socket.
6 Access your PC motherboard - refer to your computer manual or supplier if you are unsure how to do this.
7 Once you have access to your PC motherboard, locate a free PCI slot. You will need to remove the corresponding cover plate to provide an opening and fixing point for the Voyager 1040's endplate.
8 Firmly seat the BT Voyager 1040 Adapter in the PCI slot. Ensure that you only touch the edges of the adapter. Also, make sure that no contact is made with other expansion cards or motherboard components.
9 Once the adapter is in place, fasten it to the motherboard using the retaining screw from the cover plate you removed in step 7.
10 Return your PC's cover and ensure that all retaining screws are put back.
11 Plug the PC back in and boot up. Your new hardware will be detected when Windows starts up. You can confirm that the driver software has been installed because the BT Voyager Wireless Utility Icon Utility Iconwill appear in the in the bottom right of your screen.
Notes on placement
The BT Voyager 1040 PCI Adapter has a moveable antenna. A better range will be achieved if the antenna is placed pointing upwards.
Avoid putting the adapter in places that expose it to direct sunlight or high levels of humidity.
0 Comments
