Original Xbox (Xbox 1) Connection Guide
- Mark as Read
- Library
- Original Xbox (Xbox 1) Connection Guide
22-02-2010
11:00 PM
This guide will show you how to connect an original Xbox (pictured right) to Xbox LIVE. There's a separate guide for the Xbox 360.
Please note: Xbox LIVE access for original Xbox models was removed on April 15th 2010.
There are 3 ways to connect to Xbox Live:
- Direct Connection
The fast and simple way to connect to Xbox Live. - Router Connection
Play Xbox Live and connect your PC to the Internet at the same time with a broadband router. - Internet Connection Sharing
Play Xbox Live and connect your PC to the Internet at the same time. Requires a USB or PCI modem for your PC.
1. Direct Connection
Connection check list:
- An Xbox
- Broadband modem
- Standard Ethernet cable with RJ-45 connectors
Steps:
- Turn off your Xbox and modem.
- Connect the Ethernet cable to the Ethernet out port on your modem and the Ethernet port on the back of your Xbox.
- Turn on your modem. Now turn on your Xbox. Make sure there is no disk in the Xbox disk tray.
- Choose Xbox Live from the Xbox Dashboard.
[Top]
2. Router Connection
- An Xbox
- Broadband router with 2 Ethernet ports
- 2 standard Ethernet cables with RJ-45 connectors
- A spare Ethernet port on your PC (you may need to install additional Network Interface Card/s (NIC)
Steps:
- Turn off your hardware (PC, Router and Xbox).
- Connect the first Ethernet cable to an Ethernet port on your router and the Ethernet port on the back of your Xbox.
- Connect the second Ethernet cable to another Ethernet port on your router and the Ethernet port on your PC Network Interface Card (NIC).
- Turn on your router, then your PC.
- Check your PC can access the Internet - your router may require a specific configuration to do this with your PC. Refer to the router's instructions for specific support.
- Turn on your Xbox. Make sure there isn't a disk in the disk tray.
[Top]
3. Internet Connection Sharing
- An Xbox
- Broadband modem
- A standard Ethernet cable with RJ-45 connectors
- A cross-over Ethernet cable with RJ-45 connectors
- 2 spare Ethernet ports on your PC (you may need to install additional Network Interface Card/s (NIC) If you have a USB modem you will only need 1 Ethernet port
- A PC running Windows 98S, Me, 2000 Professional or XP
Steps
- Turn off your hardware (Xbox, broadband modem and PC).
- If you are using an external USB modem make sure this is connected to your computer.
- Connect the crossover Ethernet cable to a spare Ethernet port on your PC and the Ethernet port on the back of your Xbox.
- Turn on your broadband modem and PC.
- Setup Internet Connection Sharing in Windows to share your Internet connection with your Xbox. See Windows help section for more support.
- Once Internet Connection Sharing is set up, check your PC can connect to the Internet.
Please note: if using Internet Connection Sharing you will need to have your PC switched on and connected to the Internet to play Xbox Live.
[Top]
If you're having difficulties with Xbox Live, or you're looking for fellow gamers, check out our lively games discussion forum.
0
Comments
39337
Views
