www.java.com
jelv
Fixes: 10
www.java.com
Can someone check that if they are finding www.java.com is unbelievably slow over IPv6 please.
Edit: Or possibly not working at all. nslookup gives both IPv4 and IPv6 addresses, but until I forced IPv4 only for that site on my wife's PC it just wasn't responding.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
67 REPLIES 67
Midnight_Caller
Re: www.java.com
Works ok on IPv4, I don't have IPv6 to test it with.
SimonHobson
Re: www.java.com
Working for me, and I tried it with wget (so I could force -4 and -6) and got much the same performance on both IPv4 and IPv6
brueton
Re: www.java.com
wget -4 www.java.com is OK.
wget -6 www.java.com: Connection timed out.
avatastic
Re: www.java.com
adw@thunderbolt:~$ wget -6 http://www.java.com/ -O /dev/null
--2014-04-20 14:24:35--  http://www.java.com/
Resolving www.java.com (www.java.com)... 2a02:26f0:5a:281::1ba3, 2a02:26f0:5a:282::1ba3
Connecting to www.java.com (www.java.com)|2a02:26f0:5a:281::1ba3|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
--2014-04-20 14:24:35--  http://www.java.com/en/
Reusing existing connection to [www.java.com]:80.
HTTP request sent, awaiting response... 200 OK
Length: 7036 (6.9K) [text/html]
Saving to: ‘/dev/null’
100%[======================================>] 7,036      --.-K/s  in 0.003s
2014-04-20 14:24:36 (2.42 MB/s) - ‘/dev/null’ saved [7036/7036]
Working fine here, on a tunnel.
F9 member since 1999
F9 ADSL customer since 2004
F9 FTTP customer since 2024
Re: www.java.com
I just tried both IPv4 and IPv6 in different browser tabs, and they both appear to be well !  Kiss
jelv
Fixes: 10
Re: www.java.com
Caching seems to come in to play. Just tried it on my own PC and it responded immediately but CTRL+F5 and it was very slow again.
AndyH
Re: www.java.com
I'm not sure if it's related, but I've had quite a few IPv6 pages hanging today. Facebook took 30 secs to load just now (waiting for fbstatic-a.akamaihd.net).
AndyH
Re: www.java.com
@ jelv - I think it's an issue their end as the site is not dual stacked anymore. I tried manually putting in the address [2a02:26f0:5a:281::1ba3] and it's not working today.
MJN
Seasoned Pro
Fixes: 5
Re: www.java.com
It sounds like you might have a local issue. Having to wait 30s or so for a page to begin to load is a common symptom seen when IPv6 transport availability is assumed but it's not working correctly. Does my 'What is my IPv6 address?' page work for you? If not, do you get an IPv4 address when visiting the dual-stacked version?
Edit: I've just noticed that my PN /56 prefix changed recently. If yours has too have you updated any static IPv6 address assignments or other hardwired configuration you had in place?
jelv
Fixes: 10
Re: www.java.com
I'm having no trouble with other IPv6 sites. The link you gave gives my IPv6 address, I have the Firefox 4or6 extension and see other sites come up in IPv6.
jelv
Fixes: 10
Re: www.java.com
Quote from: MJN
I'd spot that because my ping graph would break!
In any case I have no assignments or hardwired configuration.
AndyH
Re: www.java.com
The site just times out now if you try and access it over IPv6:
andrew@ubuntu:~$ wget -6 www.java.com
--2014-04-22 09:48:33--  http://www.java.com/
Resolving www.java.com (www.java.com)... 2a02:26f0:5a:282::1ba3, 2a02:26f0:5a:281::1ba3
Connecting to www.java.com (www.java.com)|2a02:26f0:5a:282::1ba3|:80...
MJN
Seasoned Pro
Fixes: 5
Re: www.java.com
It works okay for me, for what it's worth:
--2014-04-22 09:27:03--  http://www.java.com/
--2014-04-22 09:27:06--  http://www.java.com/en/
Reusing existing connection to www.java.com:80.
Saving to: `/dev/null'
100%[======================================>] 7,036      --.-K/s  in 0s
2014-04-22 09:27:06 (141 MB/s) - `/dev/null' saved [7036/7036]
Re: www.java.com
I'm having no trouble accessing http://www.java.com using IPv6 (Hurricane Electric tunnel).
Although interestingly if I use http://java.com my browser defaults to IPv4, but http://www.java.com uses IPv6.
My Firefox "4or6" add-on shows the following addresses for http://www.java.com  (see attached screenshot below).
