www.java.com
- Trials
- IPv6 Trial
- www.java.com
Re: www.java.com
22-04-2014 10:45 AM
I get :
# traceroute6 -I www.java.com
traceroute to www.java.com (2a02:26f0:5a:281::1ba3), 30 hops max, 80 byte packets
1 bubbles.thehobsons.co.uk (2001:470:1f09:baa::1) 1.444 ms 1.426 ms 1.406 ms
2 SimonH-1.tunnel.tserv5.lon1.ipv6.he.net (2001:470:1f08:baa::1) 23.582 ms 26.732 ms 29.444 ms
3 v316.core1.lon1.he.net (2001:470:0:67::1) 31.150 ms 31.179 ms 31.171 ms
4 10ge3-1.core1.lon2.he.net (2001:470:0:2cd::1) 31.128 ms 31.114 ms 31.090 ms
5 ge-2-1-0-zpr1.lnt.cw.net (2001:7f8:4::4f9:1) 31.028 ms 31.002 ms 30.983 ms
6 so-0-1-0-r1-IPv6.de.cw.net (2001:5000:0:1::1) 30.981 ms 27.924 ms 27.644 ms
7 akamai-gw2.lns.cw.net (2001:5000:1100:9::2) 27.704 ms 24.903 ms 24.836 ms
8 2a02:26f0:5a:281::1ba3 (2a02:26f0:5a:281::1ba3) 23.967 ms 21.118 ms 21.073 ms
Re: www.java.com
22-04-2014 11:00 AM
Quote from: AndyH Connecting to www.java.com (www.java.com)|2a02:26f0:5a:282::1ba3|:80...
Working:
Quote from: MJN Connecting to www.java.com (www.java.com)|2a02:26f0:5a:281::1ba3|:80... connected.
Significant?
Re: www.java.com
22-04-2014 11:06 AM
Quote from: jelv Significant?
Quite possibly.
It looks like Java.com is on Akamai's delivery network, and that will use various techniques to spread load/connect users to a "near" node. it could be that not all their nodes are OK.
Re: www.java.com
22-04-2014 11:15 AM
Quote ~ Andrew$ traceroute6 www.java.com
traceroute6: Warning: e7075.dscx.akamaiedge.net has multiple addresses; using 2a02:26f0:5a:281::1ba3
traceroute6 to e7075.dscx.akamaiedge.net (2a02:26f0:5a:281::1ba3) from 2a02:16c8:2000:1100:2d05:1f12:xxxx:xxxx, 64 hops max, 12 byte packets
1 2a02:16c8:2000:1100:5246:5dff:xxxx:xxxx 0.400 ms 0.388 ms 0.328 ms
2 2a02:16c8:0:1::1a 4.664 ms 4.988 ms 6.161 ms
3 2a02:16c8:1:2::13 4.638 ms 4.694 ms 4.190 ms
4 2a02:16c8::b 4.393 ms 4.400 ms 4.315 ms
5 * *
lonap.he.net 14.801 ms
6 10ge3-1.core1.lon2.he.net 4.498 ms 9.128 ms 4.502 ms
7 ge-2-1-0-zpr1.lnt.cw.net 4.627 ms 4.494 ms 4.564 ms
8 so-0-1-0-r1-ipv6.de.cw.net 4.947 ms 5.056 ms 4.846 ms
9 akamai-gw2.lns.cw.net 5.280 ms 5.314 ms 5.793 ms
10 * * *
11 * * *
Also tried different gateways, and no difference.
Re: www.java.com
22-04-2014 11:25 AM
Re: www.java.com
22-04-2014 11:27 AM
$ mtr -6 -r -c 10 www.java.com
HOST: My-laptop Loss% Snt Last Avg Best Wrst StDev
1. 2001:470:xxxx:xxx:: 0.0% 10 3.8 4.3 3.8 6.8 1.1
2. purleigh-1.tunnel.tserv5.lon 0.0% 10 36.5 37.1 36.3 39.5 0.9
3. v316.core1.lon1.he.net 0.0% 10 33.5 35.7 32.3 42.5 3.3
4. 10ge3-1.core1.lon2.he.net 0.0% 10 34.9 38.8 34.9 42.3 2.5
5. ge-2-1-0-zpr1.lnt.cw.net 0.0% 10 34.3 36.0 32.3 46.4 4.4
6. so-0-1-0-r1-IPv6.de.cw.net 0.0% 10 33.2 34.1 32.7 38.7 1.8
7. akamai-gw2.lns.cw.net 0.0% 10 33.2 34.0 33.2 35.3 0.6
8. 2a02:26f0:5a:281::1ba3 0.0% 10 32.9 33.1 32.7 34.0 0.4
Re: www.java.com
22-04-2014 11:51 AM
I've made no changes my end - but I am unable to access a lot of IPv6 sites again.
Looking at my router log, I am getting a lot of errors all of a sudden:
Quote Apr 22 11:48:59 rc_service: dhcp6c-state 2129:notify_rc start_radvd
Apr 22 11:48:59 rc_service: dhcp6c-state 2129:notify_rc start_httpd
Apr 22 11:48:59 rc_service: waitting "start_radvd" via dhcp6c-state ...
Apr 22 11:48:59 radvd[2127]: Exiting, sigterm or sigint received.
Apr 22 11:49:00 RT-N66U: start httpd
Re: www.java.com
22-04-2014 12:13 PM
I had to disable/enable IPv6 on my router again. I will pester Asus again to let them know.
The traceroute still fails:
Quote ~ Andrew$ traceroute6 -I www.java.com
traceroute6 to e7075.dscx.akamaiedge.net (2a02:26f0:5a:281::1ba3) from 2a02:16c8:2000:1100:b820:6427:xxxx:xxxx 64 hops max, 16 byte packets
1 2a02:16c8:2000:1100:5246:5dff:xxxx:xxxx 0.437 ms 0.376 ms 0.324 ms
2 2a02:16c8:0:1::19 5.397 ms 5.075 ms 5.053 ms
3 2a02:16c8:1:2::11 4.821 ms 4.390 ms 4.297 ms
4 2a02:16c8::a 4.619 ms 4.647 ms 4.375 ms
5 2a02:16c8:1:2::3 7.136 ms 4.401 ms 4.222 ms
6 * * *
7 * * *
8 * * *
Re: www.java.com
22-04-2014 12:36 PM
Quote from: purleigh Although interestingly if I use http://java.com my browser defaults to IPv4, but http://www.java.com uses IPv6.
That would be because java.com does not have an IPv6 address!
Re: www.java.com
22-04-2014 12:43 PM
Re: www.java.com
22-04-2014 1:45 PM
Using the office DNS server (allocated by the VPN) I'm getting different IP addresses!
Non-authoritative answer:
Addresses: 2a02:26f0:26:3:8e00::1ba3
2a02:26f0:26:3:9d00::1ba3
2a02:26f0:26:3:8200::1ba3
95.100.150.140
Aliases: www.java.com
www.java.com.edgekey.net
Re: www.java.com
22-04-2014 1:56 PM
(I forced it by putting the IPs in the hosts file)
Re: www.java.com
22-04-2014 1:58 PM
Re: www.java.com
22-04-2014 2:13 PM
I tried Google's v6 DNS servers and they gave the same addresses as OpenDNS v6 DNS servers (which I use).
Re: www.java.com
22-04-2014 2:22 PM
Quote from: dave Your accounts will have a single static IPv4 and a /56 Ipv6. Our DNS platform has yet to be upgraded to IPv6 so you will be assigned Hurricane Electric's DNS servers when you connect.
