www.java.com
- Trials
- IPv6 Trial
- www.java.com
Re: www.java.com
22-04-2014 2:35 PM
Re: www.java.com
22-04-2014 2:41 PM
Re: www.java.com
22-04-2014 2:53 PM
PN (212.159.13.49 and 212.159.13.49)
Quote www.java.com. 652 IN CNAME www.java.com.edgekey.net.
www.java.com.edgekey.net. 15497 IN CNAME e7075.dscx.akamaiedge.net.
e7075.dscx.akamaiedge.net. 20 IN AAAA 2a02:26f0:5a:281::1ba3
e7075.dscx.akamaiedge.net. 20 IN AAAA 2a02:26f0:5a:282::1ba3
OpenDNS (2620:0:ccc::2 and 2620:0:cccd::2)
Quote ;; ANSWER SECTION:
www.java.com. 830 IN CNAME www.java.com.edgekey.net.
www.java.com.edgekey.net. 6066 IN CNAME e7075.dscx.akamaiedge.net.
Google (2001:4860:4860::8888 and 2001:4860:4860::8844)
www.java.com. 417 IN CNAME www.java.com.edgekey.net.
www.java.com.edgekey.net. 3976 IN CNAME e7075.dscx.akamaiedge.net.
e7075.dscx.akamaiedge.net. 19 IN AAAA 2a02:26f0:97:29e::1ba3
e7075.dscx.akamaiedge.net. 19 IN AAAA 2a02:26f0:97:2a2::1ba3
Hurricane Electric (2001:470:20::2)
www.java.com. 521 IN CNAME www.java.com.edgekey.net.
www.java.com.edgekey.net. 4179 IN CNAME e7075.dscx.akamaiedge.net.
e7075.dscx.akamaiedge.net. 20 IN AAAA 2a02:26f0:5d:289::1ba3
e7075.dscx.akamaiedge.net. 20 IN AAAA 2a02:26f0:5d:2a5::1ba3
If PN's DNS servers use Hurricane's DNS for v6, why do they give different lookups?
Re: www.java.com
22-04-2014 3:39 PM
Quote from: AndyH If PN's DNS servers use Hurricane's DNS for v6, why do they give different lookups?
PN's DNS servers are HE's DNS servers however they are anycasted hence whilst there may be a single address they are represented by multiple servers. Each one may receive a different result based on their location given the above.
Re: www.java.com
23-04-2014 12:25 PM
It's still a bit strange that I cannot access www.java.com over any v6 address though. Another mystery!
Re: www.java.com
23-04-2014 7:54 PM
Quote from: purleigh I'm having no trouble accessing http://www.java.com using IPv6 (Hurricane Electric tunnel).
Although interestingly if I use http://java.com my browser defaults to IPv4, but http://www.java.com uses IPv6.
My Firefox "4or6" add-on shows the following addresses for http://www.java.com (see attached screenshot below).
in firefox its loading on ipv4, the ipv6 is in the dns result but for whatever reason firefox is using ipv4 for the site.
Re: www.java.com
23-04-2014 9:37 PM
Re: www.java.com
23-04-2014 9:53 PM
In the 'Advanced' settings, try unticking the "Fast fallback to IPv4", and see whether IPv6 becomes preferred by default.
"Fast fallback" is the same as "Happy Eyeballs" described above.
Re: www.java.com
23-04-2014 9:54 PM
Edit: My traceroutes don't seem to be going any further than PN's network. Last hop is 2a02:16c8:1:2::8
Can anyone on the trial access http://[2a02:26f0:5a:282::1ba3] or http://[2a02:26f0:5a:281::1ba3] ?
Re: www.java.com
23-04-2014 10:47 PM
YouTube is similar, if you lookup the IPv4 address for Youtube, you get a number of IP addresses.
If you try say http://173.194.34.128/, you don't end up in youtube, but instead you get a catch all Google page.
As I said, many hosted websites need to see the URL from the browser to full resolve what you are trying to access.
Other websites that aren't hosted in that way can be accessed using the IPv6 notation, e.g. http://[2a02:68:1::4]/ = Thinkbroadband
Re: www.java.com
23-04-2014 11:19 PM
Re: www.java.com
24-04-2014 10:06 AM
@ jelv - Did you try this for www.java.com? I tried it and still it loads in v4.
Re: www.java.com
24-04-2014 11:17 AM
Quote from: jelv Can someone check that if they are finding www.java.com is unbelievably slow over IPv6 please.
Edit: Or possibly not working at all. nslookup gives both IPv4 and IPv6 addresses, but until I forced IPv4 only for that site on my wife's PC it just wasn't responding.
Re: www.java.com
24-04-2014 11:51 AM
Whatever the issue, it seems to have been fixed. The site loads in v6 fine now.
I was going to ask if your traceroutes to 2a02:26f0:5a:282::1ba3 or 2a02:26f0:5a:281::1ba3 go no further than PN's network. But now they are working ok:
Quote # traceroute6 2a02:26f0:5a:282::1ba3
traceroute to 2a02:26f0:5a:282::1ba3 (2a02:26f0:5a:282::1ba3), 30 hops max, 16 byte packets
1 2a02:16c8:0:1::12 (2a02:16c8:0:1::12) 5.351 ms 5.381 ms 5.132 ms
2 2a02:16c8:1:2::19 (2a02:16c8:1:2::19) 4.719 ms 4.381 ms 4.379 ms
3 2a02:16c8::d (2a02:16c8::d) 4.909 ms 4.553 ms 4.354 ms
4 2a02:16c8:1:2::8 (2a02:16c8:1:2::8) 4.406 ms 4.405 ms 4.373 ms
5 lonap.he.net (2001:7f8:17::1b1b:1) 4.460 ms 4.835 ms 4.526 ms
6 10ge3-1.core1.lon2.he.net (2001:470:0:2cd::1) 11.551 ms 4.988 ms 4.414 ms
7 ge-2-1-0-zpr1.lnt.cw.net (2001:7f8:4::4f9:1) 4.845 ms 5.073 ms 6.341 ms
8 so-0-1-0-r1-IPv6.de.cw.net (2001:5000:0:1::1) 5.006 ms 4.955 ms 4.977 ms
9 akamai-gw2.lns.cw.net (2001:5000:1100:9::2) 5.706 ms 6.602 ms 5.509 ms
Re: www.java.com
24-04-2014 1:10 PM
Tracing route to 2a02:26f0:5a:282::1ba3 over a maximum of 30 hops
1 1 ms <1 ms 1 ms dsldevice.lan [hidden]
2 22 ms 26 ms 22 ms 2a02:16c8:0:1::13
3 21 ms 20 ms 20 ms 2a02:16c8:1:2::17
4 20 ms 21 ms 21 ms 2a02:16c8::c
5 20 ms 20 ms 20 ms 2a02:16c8:1:2::5
6 21 ms 21 ms 20 ms 2a02:16c8:1:2::8
7 * * * Request timed out.
8 * * * Request timed out.
