Akamai v6 - peering issue?
AndyH
I am getting a lot of Facebook images that aren't loading at the moment and they are delivered/hosted by Akamai (address fbcdn-profile-a.akamaihd.net).
A traceroute shows exactly the same issue as with www.java.com (traceroute seems to go no further than PN's network):
traceroute6: Warning: a2047.dspl.akamai.net has multiple addresses; using 2a02:26f0:5a::173e:3531
traceroute6 to a2047.dspl.akamai.net (2a02:26f0:5a::173e:3531) from 2a02:16c8:2000:1100:ed61:xxxx:xxxx:xxxx, 64 hops max, 12 byte packets
1  2a02:16c8:2000:1100:xxxx:xxxx:xxxx:xxxx  0.376 ms  0.410 ms  0.330 ms
2  2a02:16c8:0:1::16  6.601 ms  6.363 ms  5.997 ms
3  2a02:16c8:1:2::19  4.591 ms  4.706 ms  4.409 ms
4  2a02:16c8::d  4.647 ms  4.575 ms  6.129 ms
5  2a02:16c8:1:2::8  4.629 ms  4.576 ms  4.989 ms
6  * * *
7  * * *
6  * * *
7  * * *
8  * * *
9  * * *
10  * * *
A traceroute from Hurricane's LG works perfectly fine:
core1.lon1.he.net> traceroute ipv6 2a02:26f0:5a::173e:356a numeric
Target 2a02:26f0:5a::173e:356a
Hop Packet 1 Packet 2 Packet 3 Hostname
1 10 ms 11 ms <1 ms 10ge3-1.core1.lon2.he.net (2001:470:0:2cd::1)
2 9 ms <1 ms <1 ms ge-2-1-0-zpr1.lnt.cw.net (2001:7f8:4::4f9:1)
3 <1 ms <1 ms <1 ms so-0-1-0-r1-IPv6.de.cw.net (2001:5000:0:1::1)
4 11 ms 2 ms 1 ms akamai-gw2.lns.cw.net (2001:5000:1100:9::2)
5 <1 ms <1 ms <1 ms 2a02:26f0:5a::173e:3531
core1.lon2.he.net> traceroute ipv6 2a02:26f0:5a::173e:356a numeric
1 13 ms <1 ms <1 ms ge-2-1-0-zpr1.lnt.cw.net (2001:7f8:4::4f9:1)
2 1 ms 1 ms 1 ms so-0-1-0-r1-IPv6.de.cw.net (2001:5000:0:1::1)
3 1 ms 1 ms 1 ms akamai-gw2.lns.cw.net (2001:5000:1100:9::2)
4 <1 ms <1 ms <1 ms 2a02:26f0:5a::173e:3531
The strange thing is that if I ping6 akamai-gw2.lns.cw.net (2001:5000:1100:9::2) and then immediately afterwards do a traceroute to a2047.dspl.akamai.net (2a02:26f0:5a::173e:3531), it works fine:
$ traceroute6 fbcdn-profile-a.akamaihd.net
traceroute6 to a2047.dspl.akamai.net (2a02:26f0:5a::173e:3531) from 2a02:16c8:2000:1100:xxxx:xxxx:xxxx:xxxx, 64 hops max, 12 byte packets
1  2a02:16c8:2000:1100:xxxx:xxxx:xxxx:xxxx  0.443 ms  0.393 ms  0.336 ms
2  2a02:16c8:0:1::16  128.809 ms  88.936 ms  57.786 ms
3  2a02:16c8:1:2::19  4.883 ms  4.462 ms  4.632 ms
4  2a02:16c8::d  5.034 ms  4.693 ms  4.671 ms
5  2a02:16c8:1:2::8  4.291 ms  4.044 ms  4.420 ms
6  lonap.he.net  4.609 ms  11.987 ms  4.885 ms
7  10ge3-1.core1.lon2.he.net  15.629 ms  4.191 ms  4.699 ms
8  ge-2-1-0-zpr1.lnt.cw.net  4.680 ms  4.639 ms  4.636 ms
9  so-0-1-0-r1-ipv6.de.cw.net  5.188 ms  9.314 ms  7.206 ms
10  akamai-gw2.lns.cw.net  5.511 ms  5.589 ms  5.252 ms
11  2a02:26f0:5a::173e:3531  4.961 ms  5.037 ms  4.885 ms
Any thoughts?
64 REPLIES 64
Kelly
Fixes: 9
Re: Akamai v6 - peering issue?
Might be something wrong on our side here. We've flagged it over to Paul to have a look.
Kelly Dorset
Ex-Plusnet Jobsbody
AndyH
Perfect. Thanks.
chrcoluk
yeah I had akamai slow loading/timeouts on another site also.
paulmh5
I've made some changes to stop traffic going over the Akamai PNI links.  Hopefully this will be a bit more stable while they have a look at what's going on.
Plusnet Staff - Lead Network Design/Delivery Engineer
AndyH
Working for me fine now - thanks.
jelv
Fixes: 10
@paulmh5
Thanks for fixing http://community.plus.net/forum/index.php/topic,126295.0.html as well.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
paulmh5
Fingers crossed Akamai have sorted the issue on their side now so I've enabled the PNIs again.  Let me know if you see issues with it.
jelv
Fixes: 10
Paul,
www.java.com gives "The server at www.java.com is taking too long to respond." over IPv6!
paulmh5
Odd, its working ok for me this morning.  Everything else working for you over v6(Facebook etc..)?
jelv
Fixes: 10
I can access IPv6 only sites such as http://loopsofzen.co.uk/.
Firefox is accessing some sites (e.g. http://www.internetsociety.org/blog/tech-matters/2014/02/google-ipv6-traffic-passes-3-deployment-rat... via IPv6 (I'm using the 4or6 add-on) - although it's doing it's usual of fast fall back to IPv4 on others.
Tracert:
C:\Users\John>tracert -6 www.java.com
Tracing route to www.java.com [2a02:26f0:26:3:8e00::1ba3]
over a maximum of 30 hops:
 1    <1 ms     1 ms     1 ms  dsldevice.lan [2a02:16c8:<removed>]
 2    21 ms    21 ms    20 ms  2a02:16c8:0:1::17
 3    21 ms    20 ms    20 ms  2a02:16c8:1:2::17
 4    22 ms    20 ms    20 ms  2a02:16c8::c
 5    20 ms    20 ms    20 ms  2a02:16c8:1:2::6
 6    23 ms    24 ms    24 ms  40ge1-3.core1.lon2.he.net [2001:7f8:4::1b1b:1]
 7     *        *        *     Request timed out.
19     *        *        *     Request timed out.
20     *     Destination host unreachable.
Trace complete.
http://ipv6.google.com/ works.
I'm seeing the issue on both pcl and ptw gateways.
jelv
Fixes: 10
I can't access http://ipv6.google.com/ at the moment.
paulmh5
Both are still working fine for me.
Have you moved to one of the new BNGs?  These will give you a pool address rather than a static if you have that in any fixed config that may cause you a problem.  Failing that I'd suggest checking your MTU size as a few people have had issues with that and some v6 services.
jelv
Fixes: 10
I'm not on a bng (does IPSEC go to bng's?).
I've not touched anything to do with MTU - so why would Google suddenly stop working? (I can tracert to it)
bobpullen
Fixes: 330
Anyone else having problems with Facebook images again?
java.com is OK, Facebook just seems a bit iffy from my desktop Huh
