www.java.com
- Trials
- IPv6 Trial
- www.java.com
www.java.com
20-04-2014 11:53 AM
Edit: Or possibly not working at all. nslookup gives both IPv4 and IPv6 addresses, but until I forced IPv4 only for that site on my wife's PC it just wasn't responding.
Re: www.java.com
20-04-2014 12:12 PM
Re: www.java.com
20-04-2014 12:23 PM
Re: www.java.com
20-04-2014 1:05 PM
Re: www.java.com
20-04-2014 2:25 PM
--2014-04-20 14:24:35-- http://www.java.com/
Resolving www.java.com (www.java.com)... 2a02:26f0:5a:281::1ba3, 2a02:26f0:5a:282::1ba3
Connecting to www.java.com (www.java.com)|2a02:26f0:5a:281::1ba3|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
--2014-04-20 14:24:35-- http://www.java.com/en/
Reusing existing connection to [www.java.com]:80.
HTTP request sent, awaiting response... 200 OK
Length: 7036 (6.9K) [text/html]
Saving to: ‘/dev/null’
100%[======================================>] 7,036 --.-K/s in 0.003s
2014-04-20 14:24:36 (2.42 MB/s) - ‘/dev/null’ saved [7036/7036]
Working fine here, on a tunnel.
F9 ADSL customer since 2004
F9 FTTP customer since 2024
Re: www.java.com
20-04-2014 3:03 PM
Re: www.java.com
20-04-2014 3:18 PM
Re: www.java.com
20-04-2014 5:03 PM
Re: www.java.com
22-04-2014 9:09 AM
Re: www.java.com
22-04-2014 9:30 AM
Edit: I've just noticed that my PN /56 prefix changed recently. If yours has too have you updated any static IPv6 address assignments or other hardwired configuration you had in place?
Re: www.java.com
22-04-2014 9:39 AM
Re: www.java.com
22-04-2014 9:41 AM
Quote from: MJN Edit: I've just noticed that my PN /56 prefix changed recently. If yours has too have you updated any static IPv6 address assignments or other hardwired configuration you had in place?
I'd spot that because my ping graph would break!
In any case I have no assignments or hardwired configuration.
Re: www.java.com
22-04-2014 9:50 AM
Quote andrew@ubuntu:~$ wget -6 www.java.com
--2014-04-22 09:48:33-- http://www.java.com/
Resolving www.java.com (www.java.com)... 2a02:26f0:5a:282::1ba3, 2a02:26f0:5a:281::1ba3
Connecting to www.java.com (www.java.com)|2a02:26f0:5a:282::1ba3|:80...
Re: www.java.com
22-04-2014 10:10 AM
wget -6 http://www.java.com/ -O /dev/null
--2014-04-22 09:27:03-- http://www.java.com/
--2014-04-22 09:27:06-- http://www.java.com/en/
Reusing existing connection to www.java.com:80.
Saving to: `/dev/null'
100%[======================================>] 7,036 --.-K/s in 0s
2014-04-22 09:27:06 (141 MB/s) - `/dev/null' saved [7036/7036]
Re: www.java.com
22-04-2014 10:23 AM
Although interestingly if I use http://java.com my browser defaults to IPv4, but http://www.java.com uses IPv6.
My Firefox "4or6" add-on shows the following addresses for http://www.java.com (see attached screenshot below).
