Akamai v6 - peering issue?
- Trials
- IPv6 Trial
- Re: Akamai v6 - peering issue?
29-04-2014 1:33 PM
A traceroute shows exactly the same issue as with www.java.com (traceroute seems to go no further than PN's network):
Quote traceroute6: Warning: a2047.dspl.akamai.net has multiple addresses; using 2a02:26f0:5a::173e:3531
traceroute6 to a2047.dspl.akamai.net (2a02:26f0:5a::173e:3531) from 2a02:16c8:2000:1100:ed61:xxxx:xxxx:xxxx, 64 hops max, 12 byte packets
1 2a02:16c8:2000:1100:xxxx:xxxx:xxxx:xxxx 0.376 ms 0.410 ms 0.330 ms
2 2a02:16c8:0:1::16 6.601 ms 6.363 ms 5.997 ms
3 2a02:16c8:1:2::19 4.591 ms 4.706 ms 4.409 ms
4 2a02:16c8::d 4.647 ms 4.575 ms 6.129 ms
5 2a02:16c8:1:2::8 4.629 ms 4.576 ms 4.989 ms
6 * * *
7 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
A traceroute from Hurricane's LG works perfectly fine:
Quote core1.lon1.he.net> traceroute ipv6 2a02:26f0:5a::173e:356a numeric
Target 2a02:26f0:5a::173e:356a
Hop Packet 1 Packet 2 Packet 3 Hostname
1 10 ms 11 ms <1 ms 10ge3-1.core1.lon2.he.net (2001:470:0:2cd::1)
2 9 ms <1 ms <1 ms ge-2-1-0-zpr1.lnt.cw.net (2001:7f8:4::4f9:1)
3 <1 ms <1 ms <1 ms so-0-1-0-r1-IPv6.de.cw.net (2001:5000:0:1::1)
4 11 ms 2 ms 1 ms akamai-gw2.lns.cw.net (2001:5000:1100:9::2)
5 <1 ms <1 ms <1 ms 2a02:26f0:5a::173e:3531
Quote core1.lon2.he.net> traceroute ipv6 2a02:26f0:5a::173e:356a numeric
1 13 ms <1 ms <1 ms ge-2-1-0-zpr1.lnt.cw.net (2001:7f8:4::4f9:1)
2 1 ms 1 ms 1 ms so-0-1-0-r1-IPv6.de.cw.net (2001:5000:0:1::1)
3 1 ms 1 ms 1 ms akamai-gw2.lns.cw.net (2001:5000:1100:9::2)
4 <1 ms <1 ms <1 ms 2a02:26f0:5a::173e:3531
The strange thing is that if I ping6 akamai-gw2.lns.cw.net (2001:5000:1100:9::2) and then immediately afterwards do a traceroute to a2047.dspl.akamai.net (2a02:26f0:5a::173e:3531), it works fine:
Quote $ traceroute6 fbcdn-profile-a.akamaihd.net
traceroute6 to a2047.dspl.akamai.net (2a02:26f0:5a::173e:3531) from 2a02:16c8:2000:1100:xxxx:xxxx:xxxx:xxxx, 64 hops max, 12 byte packets
1 2a02:16c8:2000:1100:xxxx:xxxx:xxxx:xxxx 0.443 ms 0.393 ms 0.336 ms
2 2a02:16c8:0:1::16 128.809 ms 88.936 ms 57.786 ms
3 2a02:16c8:1:2::19 4.883 ms 4.462 ms 4.632 ms
4 2a02:16c8::d 5.034 ms 4.693 ms 4.671 ms
5 2a02:16c8:1:2::8 4.291 ms 4.044 ms 4.420 ms
6 lonap.he.net 4.609 ms 11.987 ms 4.885 ms
7 10ge3-1.core1.lon2.he.net 15.629 ms 4.191 ms 4.699 ms
8 ge-2-1-0-zpr1.lnt.cw.net 4.680 ms 4.639 ms 4.636 ms
9 so-0-1-0-r1-ipv6.de.cw.net 5.188 ms 9.314 ms 7.206 ms
10 akamai-gw2.lns.cw.net 5.511 ms 5.589 ms 5.252 ms
11 2a02:26f0:5a::173e:3531 4.961 ms 5.037 ms 4.885 ms
Any thoughts?
29-04-2014 2:11 PM
Ex-Plusnet Jobsbody
29-04-2014 2:21 PM
29-04-2014 2:44 PM
29-04-2014 5:13 PM
29-04-2014 5:38 PM
29-04-2014 5:41 PM
Thanks for fixing http://community.plus.net/forum/index.php/topic,126295.0.html as well.
06-06-2014 4:21 PM
09-06-2014 9:18 AM
www.java.com gives "The server at www.java.com is taking too long to respond." over IPv6!
10-06-2014 7:06 AM
10-06-2014 8:23 AM
Firefox is accessing some sites (e.g. http://www.internetsociety.org/blog/tech-matters/2014/02/google-ipv6-traffic-passes-3-deployment-rat... via IPv6 (I'm using the 4or6 add-on) - although it's doing it's usual of fast fall back to IPv4 on others.
Tracert:
C:\Users\John>tracert -6 www.java.com
Tracing route to www.java.com [2a02:26f0:26:3:8e00::1ba3]
over a maximum of 30 hops:
1 <1 ms 1 ms 1 ms dsldevice.lan [2a02:16c8:<removed>]
2 21 ms 21 ms 20 ms 2a02:16c8:0:1::17
3 21 ms 20 ms 20 ms 2a02:16c8:1:2::17
4 22 ms 20 ms 20 ms 2a02:16c8::c
5 20 ms 20 ms 20 ms 2a02:16c8:1:2::6
6 23 ms 24 ms 24 ms 40ge1-3.core1.lon2.he.net [2001:7f8:4::1b1b:1]
7 * * * Request timed out.
19 * * * Request timed out.
20 * Destination host unreachable.
Trace complete.
http://ipv6.google.com/ works.
I'm seeing the issue on both pcl and ptw gateways.
11-06-2014 8:36 PM
11-06-2014 10:17 PM
Have you moved to one of the new BNGs? These will give you a pool address rather than a static if you have that in any fixed config that may cause you a problem. Failing that I'd suggest checking your MTU size as a few people have had issues with that and some v6 services.
11-06-2014 11:05 PM
I've not touched anything to do with MTU - so why would Google suddenly stop working? (I can tracert to it)
19-06-2014 5:39 PM
java.com is OK, Facebook just seems a bit iffy from my desktop
