Waiting a month for features to activate
B8K
I am told not to interfere with features whilst they are waiting to activated but I've waited about a month!!
Tags (2)
13 REPLIES 13
TheMightyAJ
Fixes: 126
Re: Waiting a month for features to activate
Hey @B8K,
I'm really sorry to hear about this. Which features currently aren't activated on your end?
 Alex H
B8K
My billing area says 'you currently have an order in progress' and has said that for a month. I am waiting for Voicemail and Call Protect to be activated.
B8K
It is not fixed. I pressed the fix button expecting some suggestion on how to fix it.
B8K
This is not fixed, I clicked fix by mistake, being new to the forum.
B8K
I hope you saw my reply. I am waiting for Voicemail and Call Protect to be activated. I pressed the fix key in error.
seebee
Fixes: 9
@B8K as you put the "fix" on, I think you should be able to remove it. If you choose the "Post options" dropdown menu in the post currently showing as the green one, is there an entry in there called "Not the fix" - does that remove the fix?
B8K
No, I can't seem to change it.
TheMightyAJ
Fixes: 126
Thanks for getting back to us and don't worry, we can still reply to the thread even if it's been marked as fixed Smiley
Looking at the account, the Plusnet Call Protect feature should already be active - please could you try completely unplugging the phone from the socket for a couple of minutes and then plugging it back in again to see if this makes any difference on your end?
 Alex H
B8K
Thank you. 1471 works now. Does this mean Call Protect is also active?
TheMightyAJ
Fixes: 126
That's great news! Call Protect should be active but may need setting up before you get the desired results from it. We have a guide on how to use the feature, here. Please let me know if you run into any issues and I'll be happy to help out Smiley
 Alex H
B8K
I did unplug the phone and Voicemail worked but I can't check Call Protect. On my account it still says these features are awaiting activation.....So there must be a lag between the fix and the update on my account.
Fixes: 1,660
I've placed an order to correct this which should complete within an hour. Smiley
Fixes: 1,660
@B8K
Unfortunately the exchange which your phone line is served by doesn't support Call Protect. Haven't seen this type of issue in many years as it's a rarity this happens. I'm afraid there isn't anything we can do in these cases.
I've arranged for Call Protect to be removed from your account so it's not stuck in a pending state forever more.
