Carrier pre-select 18185
NigelM
There are previous posts on this topic but none are recent so I wanted to confirm that the situation remains the same in 2017. I am moving my phone to Plusnet with the Anytime UK Calls package. Can I still use the 18185 pre-select for international calls without charge by Plusnet?
3 REPLIES 3
Fixes: 1,483
Re: Carrier pre-select 18185
yes, I use it Smiley
NigelM
I'm assuming your Yes is also confirming that you don't get charged anything by Plusnet (just by 18185) - is this correct?
Fixes: 1,483
That's correct, only charged by 18185
