Carrier pre-select 18185
FIXED- Subscribe to RSS Feed
- Home Phone
- Carrier pre-select 18185
21-02-2017 5:28 PM
There are previous posts on this topic but none are recent so I wanted to confirm that the situation remains the same in 2017. I am moving my phone to Plusnet with the Anytime UK Calls package. Can I still use the 18185 pre-select for international calls without charge by Plusnet?
Fixed! Go to the fix.
Re: Carrier pre-select 18185
21-02-2017 5:33 PM
21-02-2017 5:45 PM
I'm assuming your Yes is also confirming that you don't get charged anything by Plusnet (just by 18185) - is this correct?
21-02-2017 5:50 PM
