Call Protect online
- Home Phone
- Call Protect online
Call Protect online
09-06-2020 9:26 PM
The 'Call Protect' feature has been requested to be available online for YEARS now.
When will it be available please?
On looking through the forums (spending hours and hours) I've lost count of the requests for this to be made available online.
Is it a fact that Plusnet are not 'smart enough' to make this feature available online in our accounts section?
If this is the case, would you like me to point you in the direction of capable programmers who are able to code this for you?
Re: Call Protect online
10-06-2020 1:15 PM
10-06-2020 1:29 PM
Hi Piotr
Thank you for that, the option to select 'Call Protect' wasn't there when I wrote the forum post.
I've now selected it and it's 'awaiting activation' at the moment.
It'll be good when it's 'live' then I'll be able to add nuisance numbers to it from my PC.
I cannot believe Plusnet left it sooooo long with only the ability to add numbers using the phone keypad.
I'll reply again when it is up & running.
Thanks again.
10-06-2020 2:43 PM - edited 10-06-2020 2:45 PM
Er, no, I'm afraid you won't.
The BT system allows you to add, remove and check online.
Plusnet's version does not. It's all done on the phone. 😥
See https://www.plus.net/help/phone/call-features/ "How do I use call features?"
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
10-06-2020 3:16 PM
Thank you 198KHz
I specifically asked Plusnet about Call Protect ONLINE!
Your response leads me to believe Plusnet are 'leading me up the garden path'
Either that, or they haven't got a clue what they are doing.
Therefore, Plusnet: Please take note
Please answer my original question with truth, honesty and accuracy.
If you haven't got a clue what you are doing, please let me know if you'd like competent assistance in achieving what your customers want.
10-06-2020 3:30 PM
