FIFA 14 Crazy Input Lag - Please Help
- Gaming
- FIFA 14 Crazy Input Lag - Please Help
Re: FIFA 14 Crazy Input Lag - Please Help
04-09-2014 9:13 PM
04-09-2014 9:37 PM
04-09-2014 10:12 PM
Line state: Connected
Connection time: 1 day, 01:13:41
Downstream: 23,457 Kbps
Upstream: 1,208 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Fast
Noise margin (Down/Up): 3.1 dB / 6.5 dB
Line attenuation (Down/Up): 10.5 dB / 5.6 dB
Output power (Down/Up): 0.0 dBm / 12.1 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 164 / 3
Loss of Link (Remote): 0
HEC Errors (Down/Up): 734 / 2
Error Seconds (Local/Remote): 0 / 3
05-09-2014 5:00 AM
Tracing route to easo.ea.com [159.153.234.54]
over a maximum of 30 hops:
1 4 ms 4 ms 6 ms 192.168.1.254
2 20 ms 20 ms 22 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 19 ms 18 ms 17 ms link-a-central10.ptw-gw01.plus.net [212.159.2.144]
4 18 ms 18 ms 18 ms xe-4-2-0.ptw-cr01.plus.net [212.159.0.240]
5 154 ms 232 ms 242 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
6 * * * Request timed out.
7 92 ms 92 ms 93 ms ae-58-223.ebr2.London1.Level3.net [4.69.153.137]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 93 ms 92 ms 92 ms ae-4-90.edge2.Washington1.Level3.net [4.69.149.206]
13 93 ms 92 ms 92 ms 4.79.23.202
14 93 ms 92 ms 92 ms 159.153.93.2
15 93 ms 92 ms 93 ms 159.153.225.30
16 92 ms 92 ms 92 ms meav5-pub.pt.iad.ea.com [159.153.226.105]
17 93 ms 94 ms 95 ms easo.ea.com [159.153.234.54]
05-09-2014 8:31 AM
You didn't answer my question about DNS?
Ex-Plusnet Jobsbody
05-09-2014 7:36 PM
Anyway, is anything actually being done about the latency/lag issues plaguing plusnet customers?, I ask because I am being rebutted at every chance, this is obviously not an isolated incident, changing routers, dmz, upnp, port forwarding etc etc, does not make an iota of difference, the problem lies squarely with plusnet/bt, but is anything actually being done, or is plusnet's company line, the same as BT's, which is "we've tested our network, and can find no issues"?
08-09-2014 12:18 AM
08-09-2014 6:43 AM
Just saying things are bad isn't enough to go on.
08-09-2014 9:11 AM
Quote from: bolt786 I have my DNS servers set to opendns, if I use the normal plusnet ones, there is a huge difference between page load speeds, opendns or even google dns are far superior to the plusnet dns servers.
We don't have other people complaining of the same issues with DNS. That points to something we can look at.
Ex-Plusnet Jobsbody
08-09-2014 12:30 PM
08-09-2014 12:45 PM
08-09-2014 12:57 PM
08-09-2014 4:38 PM
Also I note, their are loads of unknown hops on the route to EA servers, so who knows, what the ping/latency is with them.
1 4 ms 3 ms 3 ms 192.168.1.254
2 20 ms 19 ms 20 ms lo0.11.central11.ptn-bng01.plus.net [195.166.128.229]
3 19 ms 20 ms 20 ms irb.11.ptw-cr01.plus.net [84.93.249.17]
4 23 ms 25 ms 26 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
5 * * * Request timed out.
7 * * * Request timed out.
11 94 ms 94 ms 95 ms ae-3-80.edge2.Washington1.Level3.net [4.69.149.142]
12 95 ms 95 ms 96 ms 4.79.23.202
13 94 ms 95 ms 139 ms 159.153.93.2
14 94 ms 94 ms 94 ms 159.153.225.30
15 95 ms 95 ms 96 ms meav5-pub.pt.iad.ea.com [159.153.226.105]
16 95 ms 95 ms 96 ms easo.ea.com [159.153.234.54]
Trace complete.
09-09-2014 1:09 PM
Are you getting white page issues with the HH3 as well?
Ex-Plusnet Jobsbody
09-09-2014 1:40 PM
