FIFA 14 Crazy Input Lag - Please Help
- Gaming
- FIFA 14 Crazy Input Lag - Please Help
- « Previous
- Next »
Re: FIFA 14 Crazy Input Lag - Please Help
08-10-2014 10:57 AM
Not quite sure how the EA server selection works. Are you connected via ethernet? 79 ping to a European server isn't great if you're on fibre. Do they give you the server IPs?
08-10-2014 11:38 AM
I get a ping of 18ms on speedtest sometimes lower.It's possible the Billion router might be faulty?
Just to add I'm connected with netgear av500 homeplugs.They've been great on all other games.I'm not at home but can post a copy of a tracert later when I get in.
08-10-2014 12:59 PM
It's unlikely to be your router that's the issue.
Homeplugs can sometimes cause issues with gaming (pings can vary quite a bit), but if it's not an issue with other games then that kind of rules that one out.
08-10-2014 2:51 PM
I understand I'll never get completely lag free gaming but with Fifa it's like running through mud a good deal of the time and sometimes as I play(only noticed when playing the clubs feature) it slows right down and then speeds up Benny Hill style as if it's skipping forward to catch back up. .But as Ive said,Ive only tried a couple of games since installing the new router so will have to give it time.
08-10-2014 5:13 PM
08-10-2014 10:15 PM
09-10-2014 9:20 AM
Are you on fibre?
09-10-2014 11:07 AM
UPDATE
Managed to get connected but my sync speed has dropped drastically, I suspect my IP profile may have change. What's the best way to sort this out?
dick:quote
09-10-2014 4:31 PM
Unfortunately I presume you've been trying for a while logging in and rebooting several times in a short period.If this is the case it may be seen as your line being unstable so it will lower your speed!You will have to leave it on now, don't reboot it again.It could take a few days or so for your profile to return to normal.
Glad you got it working though.
Just to add to Andy my xbox one is showing 0% packet loss with the Asus and got an open Nat straight away so things are looking good.The billion was a few years old and I'd never been convinced it was working properly.
09-10-2014 4:35 PM
UPDATE
I have played 3 games with the new router and I have to say it has been a massive improvement, lag has barely been noticeable like it was the the PN supplied router.
- « Previous
- Next »
