Speed issues
dsbibby
Speed issues
Hello,
Hoping @Gandalf will see this and be able to help...
I thought my FTTP service seemed a little slow today so have run a speed check on various sites (BT Wholesale, Speedtest.net and thinkbroadband.com)
I am getting varying results, but at absolute best it seems I am getting 20Mb down and 20Mb up, often times significantly worse than that. These tests all done using a wired 1GbE connection
I've tried to do the BT Wholesale Further Diagnostics tests but it's not accepting my address so need my service ID I suspect.
Any help much appreciated.
Thanks, David
7 REPLIES 7
Fixes: 1,601
Re: Speed issues
Hi David.
I think I've fixed this for you now.
Looks like this was the fallout from when your account was closed and reactivated.
The speed profile de-configured itself. Can you retest in about 5 minutes? Smiley
dsbibby
Re: Speed issues
And that really is cracking service!
Thank you so much! All working perfectly already!
(and thanks for the gift a few weeks back! Grin)
Fixes: 1,601
Re: Speed issues
Glad to hear that.
No problems at all. Cheesy
dsbibby
Re: Speed issues
Hi @Gandalf
Would you be so kind as to look in to this again for me? My speeds have dropped down again at some point to 20/20.
Many thanks,
David
Fixes: 1,601
Re: Speed issues
Hi David. Everything looks OK on your account still, and from what we can see from testing the circuit there's no major issues flagging.
Can you try rebooting your router and let us know how your speed looks afterwards?
dsbibby
Re: Speed issues
Darn it! I really should have tried that first...
... Move along, nothing to see here 🙄
Many thanks,
David
Fixes: 1,601
Re: Speed issues
Haha no worries. Smiley
