PPP LCP Send Termination Request [User request]
geffers
Folks,
Looking after my daughter's Plusnet fibre 40/2 connection, she previously suffered numerous disconnects whilst uploading, after a router fix by @bobpullen it appears to be more stable but she still suffers the occasional 'drop' as shown in the subject line.
The router log shows the following;
09:30:45, 19 Feb.	(5489424.620000) PTM over DSL is down after 8696 minutes uptime
09:30:45, 19 Feb.	(5489424.620000) PPPoE is down after 8695 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
09:30:41, 19 Feb.	(5489420.720000) PPP LCP Send Termination Request [User request]
Appreciate this was nearly six days but what puzzles me is it appears to suggest a 'user request' for termination which was not the case.
What can cause this?
Geffers
61 REPLIES 61
ejs
Aspiring Hero
Fixes: 25
Re: PPP LCP Send Termination Request [User request]
I think "PTM over DSL is down" indicates that the DSL disconnected, and what the PPP did when that happened isn't particularly significant.
SteveA
It just seems odd that the [user request] is 4 seconds before the PTM over DSL is down message
Or do you think that's just how the router handles it? What would cause the DSL to disconnect?
DS
Seasoned Champion
Fixes: 22
Although I've recently found a way that I can cause this event to occur whenever I want.....
.... it's actually nothing to do with us being the user that's requesting this drop.
Kevin
No, it is not us users requesting it. My HH5 does it every 3-7 days, although it once went for over a month without doing it!
The question is, "How do we stop it?"
Kevin.
Ex Plusnet, now Community Fibre.
SteveA
And maybe "What causes it" would  be another good question
DS
Seasoned Champion
Fixes: 22
Now that is a very good question!!
Google is inundated with this very question!!
Here's BT's answer - SeanD's post on the BTCCF
Kevin
Yes, I remember reading that post a while back and thinking "cop out".
The fact that the Hub one (basically a HH5) does it too tends to make me think it is a built in "feature" of the hub!
Kevin.
Browni
Aspiring Hero
Fixes: 61
Mine doesn't.
DS
Seasoned Champion
Fixes: 22
cop out
What ever gave you that idea ..... Roll_eyes
feature
Possibly, though I personally think it's telling us something about the BT infrastructure....Knuppel
Kevin
Interesting Browni, care to post your Info page for comparison please.
Kevin.
Kevin
Here is mine...
. Product name: BT Home Hub
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 25/06/15
4. Board version: BT Hub 5A
5. DSL uptime: 1 days, 19:11:37
6. Data rate: 19999 / 68916
7. Maximum data rate: 27283 / 69113
8. Noise margin: 15.0 / 6.4
9. Line attenuation: 14.5 / 13.8
10. Signal attenuation: 14.5 / 14.1
11. Data sent/received: 4.6 GB / 84.8 GB
12. Broadband username:
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID:
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: 1
18. 5 GHz Wireless network/SSID:
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: 48
22. Firewall: Default
23. MAC Address:
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
Kevin.
Browni
Aspiring Hero
Fixes: 61
1. Product name: Plusnet Hub
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 26/09/16
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 05:05:04
6. Data rate: 19999 / 79903
7. Maximum data rate: 31979 / 96644
8. Noise margin: 15.0 / 10.5
9. Line attenuation: 11.6 / 11.6
10. Signal attenuation: 11.5 / 11.6
11. Data sent/received: 1.6 GB / 863.5 MB
13. 2.4 GHz Wireless network/SSID:
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID:
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address:
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
I reset it earlier today for unrelated reasons, I've had 30+ days uptime before.
Kevin
You must be sitting on top of the cabinet with those speeds!Shocked
Yours is the Hub One version which uses slightly different firmware.
Does anybody know if is possible to change a HH5 to a Hub One?
Kevin.
geffers
Here's mine.
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 16/10/16
5. DSL uptime: 0 days, 08:31:40
6. Data rate: 1998 / 36138
7. Maximum data rate: 5121 / 35304
8. Noise margin: 11.7 / 5.6
9. Line attenuation: 30.4 / 21.3
10. Signal attenuation: 32.8 / 19.7
11. Data sent/received: 35.3 GB / 220.9 GB
13. 2.4 GHz Wireless network/SSID: PLUSNET-HRT7
17. 5 GHz Wireless network/SSID: PLUSNET-5ghz
22. MAC Address:
Cannot figure out how to increase the size of the table Sad
Geffers
