PPP LCP Send Termination Request [User request]
- Full Fibre
- Re: PPP LCP Send Termination Request [User request...
19-02-2017 12:11 PM - edited 19-02-2017 12:12 PM
Folks,
Looking after my daughter's Plusnet fibre 40/2 connection, she previously suffered numerous disconnects whilst uploading, after a router fix by @bobpullen it appears to be more stable but she still suffers the occasional 'drop' as shown in the subject line.
The router log shows the following;
09:30:45, 19 Feb. (5489424.620000) PTM over DSL is down after 8696 minutes uptime 09:30:45, 19 Feb. (5489424.620000) PPPoE is down after 8695 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 09:30:41, 19 Feb. (5489420.720000) PPP LCP Send Termination Request [User request]
Appreciate this was nearly six days but what puzzles me is it appears to suggest a 'user request' for termination which was not the case.
What can cause this?
Geffers
Re: PPP LCP Send Termination Request [User request]
19-02-2017 12:49 PM
I think "PTM over DSL is down" indicates that the DSL disconnected, and what the PPP did when that happened isn't particularly significant.
19-02-2017 1:17 PM
It just seems odd that the [user request] is 4 seconds before the PTM over DSL is down message
Or do you think that's just how the router handles it? What would cause the DSL to disconnect?
19-02-2017 2:34 PM
Although I've recently found a way that I can cause this event to occur whenever I want.....
.... it's actually nothing to do with us being the user that's requesting this drop.
19-02-2017 2:59 PM
No, it is not us users requesting it. My HH5 does it every 3-7 days, although it once went for over a month without doing it!
The question is, "How do we stop it?"
19-02-2017 3:02 PM
And maybe "What causes it" would be another good question
19-02-2017 3:04 PM
Now that is a very good question!!
Google is inundated with this very question!!
Here's BT's answer - SeanD's post on the BTCCF
19-02-2017 3:18 PM
Yes, I remember reading that post a while back and thinking "cop out".
The fact that the Hub one (basically a HH5) does it too tends to make me think it is a built in "feature" of the hub!
19-02-2017 3:21 PM
Mine doesn't.
19-02-2017 3:23 PM
cop out
What ever gave you that idea ..... ![]()
feature
Possibly, though I personally think it's telling us something about the BT infrastructure....![]()
19-02-2017 3:55 PM
Interesting Browni, care to post your Info page for comparison please.
19-02-2017 3:57 PM
Here is mine...
. Product name: BT Home Hub
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 25/06/15
4. Board version: BT Hub 5A
5. DSL uptime: 1 days, 19:11:37
6. Data rate: 19999 / 68916
7. Maximum data rate: 27283 / 69113
8. Noise margin: 15.0 / 6.4
9. Line attenuation: 14.5 / 13.8
10. Signal attenuation: 14.5 / 14.1
11. Data sent/received: 4.6 GB / 84.8 GB
12. Broadband username:
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID:
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: 1
18. 5 GHz Wireless network/SSID:
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: 48
22. Firewall: Default
23. MAC Address:
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
19-02-2017 5:28 PM
| 1. Product name: | Plusnet Hub |
| 2. Serial number: | |
| 3. Firmware version: | Software version 4.7.5.1.83.8.226 Last updated 26/09/16 |
| 4. Board version: | Plusnet Hub One |
| 5. DSL uptime: | 0 days, 05:05:04 |
| 6. Data rate: | 19999 / 79903 |
| 7. Maximum data rate: | 31979 / 96644 |
| 8. Noise margin: | 15.0 / 10.5 |
| 9. Line attenuation: | 11.6 / 11.6 |
| 10. Signal attenuation: | 11.5 / 11.6 |
| 11. Data sent/received: | 1.6 GB / 863.5 MB |
| 12. Broadband username: | |
| 13. 2.4 GHz Wireless network/SSID: | |
| 14. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
| 15. 2.4 GHz Wireless security: | WPA2 |
| 16. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
| 17. 5 GHz Wireless network/SSID: | |
| 18. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
| 19. 5 GHz Wireless security: | WPA2 |
| 20. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
| 21. Firewall: | Default |
| 22. MAC Address: | |
| 23. Modulation: | G.993.2 Annex B |
| 24. Software variant: | AA |
| 25. Boot loader: | 1.0.0 |
I reset it earlier today for unrelated reasons, I've had 30+ days uptime before.
19-02-2017 5:48 PM
You must be sitting on top of the cabinet with those speeds!![]()
Yours is the Hub One version which uses slightly different firmware.
Does anybody know if is possible to change a HH5 to a Hub One?
19-02-2017 6:07 PM - edited 19-02-2017 6:17 PM
Here's mine.
Plusnet Hub One | Software version 4.7.5.1.83.8.226 | Last updated 16/10/16
Cannot figure out how to increase the size of the table Geffers
- Full Fibre
