PPP LCP Send Termination Request [User request]
- Full Fibre
- PPP LCP Send Termination Request [User request]
Re: PPP LCP Send Termination Request [User request]
19-02-2017 6:17 PM
@Kevin wrote:
You must be sitting on top of the cabinet with those speeds!
Yours is the Hub One version which uses slightly different firmware.
Not qiute sitting on top of it but close! 283.7m
It was the Hub One you mentioned in your post, hence my reply.
Sell the HH5 on ebay and buy a Hub One?
@Kevin wrote:
Does anybody know if is possible to change a HH5 to a Hub One?
19-02-2017 6:20 PM
Thought the HH5 and Hub 1 were the same - though having said that BT give out a wee bit or the connection to passing customers.
Geffers
19-02-2017 6:22 PM
My home hub 5 only stays connected for 12 days at a time don't know why it does that my older HH5A did the same thing even with a stable line.
19-02-2017 6:24 PM
And this is mine:
| 1. Product name: | Plusnet Hub |
| 2. Serial number: | +081441+NQ64721019 |
| 3. Firmware version: | Software version 4.7.5.1.83.8.226 Last updated 11/02/17 |
| 4. Board version: | Plusnet Hub One |
| 5. DSL uptime: | 0 days, 06:52:56 |
| 6. Data rate: | 7865 / 46447 |
| 7. Maximum data rate: | 7865 / 48044 |
| 8. Noise margin: | 6.1 / 5.6 |
| 9. Line attenuation: | 34.7 / 24.1 |
| 10. Signal attenuation: | 34.2 / 22.2 |
So same H1 firmware version - just a later date as its only been online for a couple of weeks.
19-02-2017 6:26 PM
19-02-2017 6:32 PM
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ644*****
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 22/12/16
4. Board version: Plusnet Hub One
5. DSL uptime: 3 days, 07:49:47
6. Data rate: 2001 / 25405
7. Maximum data rate: 2210 / 24591
8. Noise margin: 7.1 / 6.0
9. Line attenuation: 31.8 / 27.3
10. Signal attenuation: 31.9 / 24.7
11. Data sent/received: 1.4 GB / 60.3 GB
21. Firewall: Default
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
Browni might not be seeing these, but the uptime is low.....
And he's on a static IP 81........
So possibly the question should be who's on a static and do they see the error in the subject heading.....?
And @snadge and myself both find we have to reboot our PNH1's every 14 days or so as anything connected to it starts to crawl.....
19-02-2017 6:35 PM
I'm on Static and get it - had it earlier today when it looks like the actual line went down
19-02-2017 6:52 PM
I think everyone will see the log message in this thread's subject line whenever their connection drops - it's a standard log message. The "User request" part indicates that something killed the pppd process. So probably what happens is that something in the firmware detects that the underlying DSL connection is down, and kills the pppd process. Unfortunately it writes a log message about the DSL being down after it has terminated the PPP, rather than before.
A disconnection once every few days is not going to be considered a fault. It probably would not be worthwhile attempting to determine the exact cause of such infrequent disconnections.
19-02-2017 6:54 PM
I'm on static too.
BT were supposed to have fixed the re-booting, but that was people having multiple ones per day. There is obviously an underlying bug which is activated by some lines/noises/dslams or something. Because some HH5's do, some don't and ditto for Hub ones....
Ex Plusnet, now Community Fibre.
19-02-2017 6:57 PM - edited 19-02-2017 7:00 PM
Well that solves that then!! ![]()
But @jamesanstee is using a 5b, I didn't think they worked on PN.....?
edit. regarding the user request, I can confirm it also happens on 51. 52. and currently 146. IP ranges (though dynamic here).
19-02-2017 7:01 PM
You are probably correct ejs, it's just that I hate not having solutions for things. (I fix stuff for a living).
There'll be an answer somewhere...... ![]()
19-02-2017 7:02 PM
The HHB Type B does work with plusnet , also have static IP in the 195 range
19-02-2017 7:09 PM
Could have sworn that PN have stated they don't, but hey ho ![]()
19-02-2017 7:23 PM
@Browni I thought I was that distance from cab as well, so have just asked for the GEA test in that other thread.
Maybe it *is* a line quality thing and the HH5/Hub One chipset thing?![]()
20-02-2017 12:06 PM - edited 20-02-2017 12:08 PM
Just running the test now...
And, here it is:
| GEA Test Detail | |||
| Circuit ID | NA | Service ID | BBEU#################### |
| Test Outcome | Pass | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
| Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
| Main Fault Location | OK | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 68.9 Mbps | ||||
| Upstream Speed | 20.0 Mbps | ||||
| Appointment Required | N | ||||
| Fault Report Advised | N | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Pass | ||||
| Bridge Tap | Not Detected | ||||
| Radio Frequency Ingress | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Cross Talk | Not Detected | ||||
| Estimated Line Length In Metres | 376.0 | ||||
| Upstream Rate Assessment | Very Good | ||||
| Downstream Rate Assessment | Reasonable | ||||
| Interference Pattern | Not Detected | ||||
| Service Impact | No Impact Observed | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
| Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
- Full Fibre
