FTTP Upgrade
Fixes: 391
Re: FTTP Upgrade
@beeceegee Agreed, but I think it is a little suspect. I have known that site to tell me I'm getting ~100Mbps on a 40/10 FTTC connection, but it is usually reliable.
Fixes: 1,495
Re: FTTP Upgrade
It's the most reliable and consistent one I've found, closely followed by TBB.
Teece
Re: FTTP Upgrade
@dvorak - that's the 900/115 service, I assume?
Fixes: 1,495
Re: FTTP Upgrade
@Teece - Yup Smiley
Fixes: 1,665
Re: FTTP Upgrade
@jamsey66 wrote:
Just a update, upgrade went live today did speed test and this is the result, Thanks for the advice and help
Nice! Looking good. Thumbs_Up
@beeceegee wrote:
That's an impressive download speed for a 145 service 😲
It is indeed. I’ve provisioned it on the wrong profile by mistake. I’ll correct when I’m in the office next week. Smiley
Teece
Re: FTTP Upgrade
@Gandalf Booo! 😂
Fixes: 1,665
Re: FTTP Upgrade
@Teece, haha I give and then I take it away. Cheesy
beeceegee
Fixes: 5
Re: FTTP Upgrade
@Gandalf wrote:
Thumbs_Up
It is indeed. I’ve provisioned it on the wrong profile by mistake. I’ll correct when I’m in the office next week Smiley
Sorry @jamsey66 think I've just cost you 60Mb/s. I'll keep quiet in future Embarrassed
Fixes: 1,665
Re: FTTP Upgrade
I actually spotted my mistake just as I finished placing the order. I figured it’d be easier to reprovision once it’d gone through rather than cancelling and replacing it.
jamsey66
Re: FTTP Upgrade
Huuummmm, don't want you to get into trouble 😂, im sure I can forgive you 😢
jamsey66
Re: FTTP Upgrade
Thinking about it over the weekend I might as well go for the 300Mb speed, can you advise
TIA James
Fixes: 1,665
Re: FTTP Upgrade
Haha I'm afraid I can't leave you on that as I'll need to correct things as part of what we call "supplier asset reconciliation", which basically makes sure the package we're selling matches the product we've ordered from our suppliers. If I don't do it, someone else will. Wink If you're wanting to upgrade, I can hold off for a couple of days though so we don't have to place two orders and you'd be best speaking with our Customer Options Team again on 0800 013 2632.
jamsey66
Re: FTTP Upgrade
Just upgraded to 300 for £3 more a month, bit of a no brainer, appreciate your previous comments one has to try lol
Fixes: 1,665
Re: FTTP Upgrade
Nice! Absolutely, if you don't ask, you don't get. Cheesy
The upgrade should go through tomorrow, let us know how it goes.
jamsey66
Re: FTTP Upgrade
Indeed, I will
James
