FTTP Upgrade
jamsey66
Re: FTTP Upgrade
Ive been told by a friend who has FTTP 500 that I can have 500 for a trial run of 14 days and if I decide that it is not for me I can revert back to 300, is this possible
TIA
James
Fixes: 1,655
Re: FTTP Upgrade
We don't offer a trial, but there is a 14 day cooling off period which begins from the day after you place an order with us. It's a period of time you can use to go back onto a previous agreement if you wanted to. So while you wouldn't get 14 days to 'trial' the service, depending when the upgrade completes, which is normally next day, you should still get some time.
jamsey66
Re: FTTP Upgrade
I thought as much thanks for the info
jamsey66
Re: FTTP Upgrade
Gandalf,
Ok ive decided to go for the 500m 🙄 its a round number 😂, is that something you can do or shall I phone on mon
Regards
James
SammyM
Fixes: 101
Re: FTTP Upgrade
You would need to call our customer options team @jamsey66 on 0800 013 2632 and they can sort that for you.
Please get back to me if you need any further help Smiley
 Sammy M - Sheffield Team
jamsey66
Re: FTTP Upgrade
Hi Sammy
Did it this morning should be up and running tomorrow
Thanks for the reply
James
SammyM
Fixes: 101
Re: FTTP Upgrade
That is fantastic news Cheesy
Have ha lovely Sunday.
jamsey66
Re: FTTP Upgrade
Hi Sammy
Just checked, hasn't gone live yet, ill check later this evening
James
Fixes: 1,655
Re: FTTP Upgrade
Hi James,
The upgrade order's still going through the supplier systems so hopefully at some point tonight you'll have faster speeds. Smiley
jamsey66
Re: FTTP Upgrade
jamsey66
Re: FTTP Upgrade
Hi, Had this email this morning, I didn't request this and I thought interleaving was kept on with FTTP and only turned off with ADSL+ connections
Regards
James
We have asked our wholesale broadband suppliers to turn interleaving off at your request.
The stability of your service may suffer as a result of turning interleaving off. If you have problems and want to turn interleaving back on, you will need to use the Broadband Fault Checker.
Interleaving usually takes 24 hours to turn off, but can take up to 5 days to take effect.
Kind regards,
Plusnet Customer Support
www.plus.net
Teece
Re: FTTP Upgrade
Interleaving ONLY applies to copper phone lines, so it's irrelevant for FTTP.
Althouth the BT site says it can't be turned off for Fibre - so worth asking...
Fixes: 1,655
Re: FTTP Upgrade
As far as I'm aware interleaving isn't a thing for FTTP, but as there's no way we can turn it on or off for an FTTP connection, I'd ignore the email. Interestingly our systems sent the email at the precise time the order completed with our suppliers.
It's likely our systems way of saying the order's completed. I'll flag it up in case it's a regular thing as it may cause confusion.
jamsey66
Re: FTTP Upgrade
Thanks for that makes sense, just did speed test results below, I assume speed will increase after a couple of days
Fixes: 1,655
Re: FTTP Upgrade
The account change hasn't completed yet so yeah I'd wait to see what your speed looks like tonight or tomorrow morning.
