FTTP installed today but my speeds are capped at 70-80mbps?
ianbr
As the title says, i got my FTTP installed today and i should have the 550mbps service but im only getting around 70-80mbps on both upload and download. I've tried connecting direct to the router using cat6 ethernet, PC is more than capable and so is my work laptop (again cabled).
Is there a period before i get the speeds i should?
5 REPLIES 5
Fixes: 555
Re: FTTP installed today but my speeds are capped at 70-80mbps?
Yes, you need to wait for the account change process to complete later today.
RHines
Yep. Totally normal. It should hit some time tonight, you'll get a confirmation email / sms.  When that happens, reboot your router and test again. I had the same issue. Smiley
ianbr
Well i had my confirmation of service change and rebooted my router and im up to 350mbps now but still not the 500-550mbps. Upload is still where it should be for the service. Rebooted the router a few times since and it seems im stuck here for now.
Fixes: 555
Wired or wireless ?
What router are you using , Plusnet Hub 2 ?
ianbr
Panic averted. I had a brain fart and double checked where my USB ethernet adapter was plugged in, turns out a USB 2 port. Plugged it into a 3.0 port and instantly up to 500-550.
Everything's sorted now 👍
