FTTP Upgrade
jamsey66
FTTP Upgrade
Hi, I have read that PN will be offering FTTP, I have FTTP with you and was wondering if my speed can be increased to 100+
TIA
James
45 REPLIES 45
Fixes: 385
Re: FTTP Upgrade
@jamsey66 Do you mean you have FTTC with PN? Have you got the Full Fibre network in your area?
jamsey66
Re: FTTP Upgrade
No I have FTTP was on the trial years ago and they extended it for me, the whole of my area including the exchange is full fibre up to 1G
J
Fixes: 385
Re: FTTP Upgrade
OK. The only way you can get FTTP is by calling in, at the moment. It is for existing customers only at the moment until the FTTP site is up. Speeds/prices have been quoted on this site - have a look at the big post on the Full Fibre board, but you may get a lower price. Be aware it is Fibre broadband only - you will lose your landline number.
Fixes: 117
Re: FTTP Upgrade
@jamsey66
If you're on the FTTP Trial then you can upgrade to a higher speed. You'll need to agree a new contract but you'll get a new Hub2 (if you ask). You need to phone PlusNet Customer Options on 0800 013 2632. Look at post #7 in the PlusNET Full Fibre thread on the forum and you'll see the speeds available and the end of contract prices (actual cost is by negotiaton).
Note this is an Internet only service and you would lose your phone line (and number) if you sign up. However as a Trial member you can port your phone number to a VOIP provider first. You must mention it on here to ensure this doesn't termination your internet connect and needs to be done before your upgrade. @Gandalf usually helps out in this.
Re: FTTP Upgrade
Forum topic - "Plusnet Full Fibre"
jamsey66
Re: FTTP Upgrade
Thanks for the advice, I will call them, I haven't had a landline for 3yrs I wasn't using it and negotiated FTTP only, will give the number a ring and let you all know how I get on, many thanks for all your reply's
James
Fixes: 1,662
Re: FTTP Upgrade
Hey James,
Upgrading your FTTP service shouldn't be a problem. Let me know how the call goes.
Teece
Re: FTTP Upgrade
Let us know what price you manage to negotiate!
jamsey66
Re: FTTP Upgrade
Hi, been trying most of this morning, anything you could do
jamsey66
Re: FTTP Upgrade
Got through just negotiating
jamsey66
Re: FTTP Upgrade
All done got Hub 2 and 145Mb for £33.99 which is double the speed for £4 more per month than I am paying now for 24months
Fixes: 1,662
Re: FTTP Upgrade
Excellent!
I've just had a look and the upgrade should be going through at some point tomorrow for you.
jamsey66
Re: FTTP Upgrade
Just a update, upgrade went live today did speed test and this is the result, Thanks for the advice and help
beeceegee
Fixes: 5
Re: FTTP Upgrade
That's an impressive download speed for a 145 service 😲
