Connected but no internet and no solution
Irene70
Re: Connected but no internet and no solution
@Mustrum @MisterW @jab1
Checked the hub manager page and for some reason the user name had reverted back to 'myusername@plusdsl.net'.
I've entered bthomehub@btbroadband.com again and it's back on. Not sure how long for this time! Again, fingers crossed!
Irene
Mustrum
Fixes: 81
@Irene70   I think at least we have got a bit further than PN have so far, as to the cause, you might be right, is your neighbour now working ok?
Ah just seen your latest reply - that suggests the PN server knows you are out there and is trying to connect you.
Irene70
@Mustrum haven't spoken with neighbour yet but will speak to him when I see him. I only moved into this house in December so don't know him too well yet 🙂
Do you think that the issue is solved and it will stay working now?Huh
I hope so!
Irene
Irene70
@Mustrum you've definitely helped me more that several phone calls to PN AND 2 engineer visits!  🙂
I'm chuffed!
Just scared it goes again lol
Irene
Fixes: 558
The first engineer to arrive told me he had been out at one of my neighbours the day my broadband crashed. He mentioned my neighbour and I somehow had our information mixed up together in some way (possibly serial numbers though I'm not sure). I'm convinced his visit to my neighbour knocked my service off with whatever he had done that day.
That's probably not coincidental!
Looks like something is wrong in the Openreach/BTw routing. I suspect your connection needs reconstructing in the OR/BTw systems.
Mustrum
Fixes: 81
@Irene70    alas no it is not sorted, you are just using the standard BT Retail username, we/PN need to get you on to their system. But you have a tale to tell the next engineer who comes out or you speak to PN.
Irene70
@MisterW @Mustrum
Does PN monitor these chats so they will perhaps pick up and be more clued up on what the issue is with my internet connection?
Irene
Mustrum
Fixes: 81
@Irene70   they do look, but it is a weekend so not something to relie on.Tagged @Gandalf  in case he is looking for a small challenge!!
Irene70
@Mustrum thankyou! Can i continue to use this in the interim?
Irene
Mustrum
Fixes: 81
@Irene70   were it me I would whilst I  can, but there is no way to say if it will last, so still needs sorting properly.
Irene70
I'll let you know if there's any developments. Just hope this temporary fix holds it till PN get on to it 🙂 Thanks again!
Irene
RobPN
Fixes: 13
I'm wondering if this could be a repeat of the incident which took out quite a few of us on FTTP about 4 months ago.
See this thread FTTP Fault where @Gandalf identified the problem at Message #5 of the thread.
It was eventually corrected for me and other users, but I'm not convinced I wasn't affected by the same problem a few days later when I was faced with no Internet and exactly the same symptoms, see FTTP fault - AGAIN!!!
adamwalker
Fixes: 223
Hi @Irene70, feel free to send me a PM with your username so I can have a look into this for you.
 Adam Walker
Irene70
@adamwalker I've sent you a PM. Thank you.
Irene
Fixes: 357
@Irene70 Please keep us up to date on this - I am now intruiged, having read today's comments. 😀
