Can only connect with setup@plusdsl.net
tombarkerphoto
So just encountered an issue where i've changed from using an Apple airport to connect to my plus net service through WAN to using the plus net router (I'm pretty sure it's the latest one). Anyway when I attempt to connect through PPP the plus net router will not connect with my username (username@plusdsl.net) and password - and yes i've checked the password is correct! If I switch the router configuration round to using the airport then that will connect with PPP with no issues... the only way i've been able to make the plus net router connect is by using setup@plusdsl.net but then I can only access the plus.net website.
Any ideas how I can get the plus.net router online?
Cheers,
Tom
7 REPLIES 7
notmyname
Re: Can only connect with setup@plusdsl.net
Not sure what would be causing that, but I'd recommend editing out your username from your post Tom Smiley
Fixes: 1,483
Just trying to clarify your setup.
You had:
airport -> vdsl modem -> phone socket
now:
Hub one -> vdsl modem -> phone socket
Is that correct?
If so you don't need to plug your hub one into the mode, it already has a vdsl modem in it and you can connect that straight to the phone socket. I'd try that.
You can check your model of router here https://www.plus.net/help/broadband/router-setup-guides/
tombarkerphoto
I'm on the trial for FTTP (fibre to the premises) so we have an ONT that connects to the router, my setup is:
Hub One ->ONT
I've checked with plus.net and it turns out my account has been ceased for some reason...... having to call up tomorrow to resolve it but hopefully will be back online soon after!
Fixes: 1,483
Moderators Note.
Moved to FTTP trial as it's an FTTP connection.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Really sorry to see that this has happened. You don't appear to have been ceased. I believe I've fixed it for you. Give it a try, maybe reboot the router, and you should be online.
 Tony T
Rachanna
I’m having the same issue!
Jubby
All Star
Fixes: 31
Hi @Rachanna and welcome to the forums!
Please accept my apologies for the issue with your broadband service.
After testing the line, I can now see that you have since connected the service. The connection is stable and operating within the estimated speed.
Feel free to get back in touch if we can be of any assistance.
Thank you.
 Lewis G
 Infrastructure Operations Professional
