what should i do
FIXED- Subscribe to RSS Feed
- Re: what should i do
on 02-05-2016 8:04 AM - last edited on 06-05-2016 10:18 AM by Mav
Ok I'm going to post 3 pictures of my router stats
The first is how the connection has been for a while....
The second is after a power cut......
The third is what I've come home to after a weekend away ...
I have powered down the router a couple of times to get it to sync at a higher rate but it would seem stuck..
Should i wait for the DLM to sort this or is there something PlusNet can do....
Moderator's note by Mike (Mav): OP's email removed from attachments
Fixed! Go to the fix.
02-05-2016 10:54 AM
03-05-2016 10:32 AM - edited 03-05-2016 10:32 AM
To be fair it's already gone up a bit this morning so hopefully won't take to long
03-05-2016 10:48 AM
IIRC changes are made by DLM early hours in the morning
If you Like it, give it a
03-05-2016 10:53 AM
05-05-2016 6:52 AM
Line is more or less back to normal..
Just my PlusNet current line speed is about 10 meg out could you please give it a nudge in the right direction...
Cheers
05-05-2016 9:18 AM
As this is a public forum, you really should hide the personal details - your sign in/email for example..
05-05-2016 3:41 PM
05-05-2016 3:54 PM
Cheers buddy
