what should i do
scottymc
what should i do
Ok I'm going to post 3 pictures of my router stats
The first is how the connection has been for a while....
The second is after a power cut......
The third is what I've come home to after a weekend away ...
I have powered down the router a couple of times to get it to sync at a higher rate but it would seem stuck..
Should i wait for the DLM to sort this or is there something PlusNet can do....
Moderator's note by Mike (Mav): OP's email removed from attachments
8 REPLIES 8
adamwalker
Fixes: 221
Re: what should i do
Hi there, DLM is entirely automated for fibre connections but I imagine you'd see some improvement if line conditions stay as they are for the next few days.
 Adam Walker
scottymc
Cheers Adam
To be fair it's already gone up a bit this morning so hopefully won't take to long
etdsaunders
Fixes: 7
Just don't power cycle router or this will make DLM delay making changes.
IIRC changes are made by DLM early hours in the morning
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs_Up
adamwalker
Fixes: 221
Good to hear!
Thanks for letting us know and do shout up if that becomes a problem again!.
 Adam Walker
scottymc
Hi Adam,
Line is more or less back to normal..
Just my PlusNet current line speed is about 10 meg out could you please give it a nudge in the right direction...
Cheers
Mustrum
Fixes: 77
As this is a public forum, you really should hide the personal details - your sign in/email for example..
HarryB
Fixes: 256
I've given the profile on our side a nudge, hopefully that helps Smiley
 Harry Beesley
scottymc
So I see
Cheers buddy
