upgrade to fibre extra speed low
Lucyb09
Re: upgrade to fibre extra speed low
Sure cancel if needed. Although one person said their was an fault your side and an engineer would be needed. But yeah cancel if it's been sorted or whatever. Thanks
RandallFlagg
Fixes: 75
Hi @Lucyb09
I've just retested the line and the results on the speed side of things were inconclusive.
Providing it's OK with yourself, I'd suggest keeping this in place just so that everything can be checked.
If it comes back with no fault found, we'll negate any potential charge.
Best wishes
Dave
Lucyb09
Ok cool. Thanks I'll go with what you say and keep it
RandallFlagg
Fixes: 75
Lovely.
Let us know how you get on on Monday.
Kind regards,
Dave
Lucyb09
Hey engineer just left. He said he rang up and asked for a reset. And changed the faceplate to a recent one. He said he couldn't see a fault or anything though.
Optimatts
Fixes: 19
Hi there @Lucyb09 I've just checked the notes and tested your line.
I don't want to prematurely determine the fault is resolved as the engineer only came out this morning but your line is looking solid and back within estimates. My test just gave your sync at 52.5Mbps.
Hopefully that's the problem solved.
However, as it is early days I've forwarded the fault ticket back to you. This way the report will stay open for a further 14 days and should you notice any further issues, if you let us know, we can pick up from where we left off.
Optimistically speaking though, we shouldn't need to!
Lucyb09
Can I just confirm I won't be charged? It was at around 60 before he came but person before said their was an fault still or something. Thanks
adamwalker
Fixes: 221
Hi Lucyb09, I've just checked and the visit isn't chargeable so don't worry about that and do shout up if you have any more issues we  need to look at for you.
 Adam Walker
Lucyb09
Hey. So at the moment it's at 55mb. It has been 60 before engineer came. Buttttttt when I do a speed test it never goes above 46-47 at a push I know you lose some speed but seems a bit much to me. Thanks!
MatthewWheeler
Fixes: 480
Thanks for getting back to us @Lucyb09
We've tested your line and we can't see any issues remotely.
Can you confirm if you've been testing over a wired or wireless connection? If wireless can you try a wired connection to see if you get similar results?
 Matthew Wheeler
Lucyb09
Hey it was over wireless yeah. But just tried wired and more or less exactly the same
TheMightyAJ
Fixes: 126
Hi @Lucyb09,
Please could you confirm if the router is still setup within the test socket in the property when running these tests? If not, please could you connect it to the test socket and send us the results of a wired speedtest?
 Alex H
Lucyb09
It's back in the normal socket now , the engineer had a look at it and changed the faceplate etc and said it's all fine. I'll sort it out tomorrow and then send the results
MasterOfReality
Fixes: 57
Ok @Lucyb09, thanks for letting us know.
We're here if you need anything else.
 - MoR
Lucyb09
Not had chance to do a wired speed test and post the results so far. I do notice my router is saying 59mb down but in my plusnet settings it says 52. Using bt hub 6. And still only getting 46 in a speed test wireless and wired
