GEA Test Request
sweeep1963
GEA Test Request
Hi, Could I have a GEA test on my line please.
Thanks.
3 REPLIES 3
SammyM
Fixes: 96
Re: GEA Test Request
Hello  @sweeep1963,
I have posted a GEA test below, please get back to us if you are experiencing any problems with your connection.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 52.3 Mbps
Upstream Speed 10.7 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 711.6
Upstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ;00:00to23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Parameters MIN MAX AVG
Down Stream Line Rate 54.6 Mbps 55.3 Mbps 55.2 Mbps
Up Stream Line Rate 10.6 Mbps 10.7 Mbps 10.7 Mbps
Up Time 795.0 Sec 900.0 Sec 899.7 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-08-26T09:49:01Z 2019-08-26T10:04:01Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Sammy M - Sheffield Team
sweeep1963
Hi, thank you for the response. Is there any way the line could return to retransmission low, as I believe this is why our speeds only seem to reach a maximum of about 47, despite the sync rate being mid 50s. We have had speeds of over 50 without any problems in the past.
Many thanks.
Mads
Fixes: 79
Hey @sweeep1963,
No worries, we're unable to influence the re transmission low as this is all up to the DLM settings on your profile. It might be worth looking at this website for more info.
Thanks.
