upgrade to fibre extra speed low
- upgrade to fibre extra speed low
- « Previous
- Next »
Re: upgrade to fibre extra speed low
26-08-2019 1:29 PM
Don't worry if you've not had time to do it as yet - there's no deadline or anything like that.
For reference, we're showing that the router is 'in sync' at 59.6mbps.
26-08-2019 2:42 PM
hey , just had a bit of time to do a wired test and post the results, pic attatched
26-08-2019 6:09 PM - edited 26-08-2019 6:13 PM
Thanks for getting back to us @Lucyb09
It looks like a prompt from Microsoft is blurring the screenshot you've posted.
Could you try that one more time please?
[edit]
Ignore me, the Microsoft pop up wasn't in the image it was a pop up on my PC.
I'm looking into this further and will add another reply soon.
[edit 2]
Were there any other devices using your broadband connection or any background tasks open on the laptop/computer you were using at the time you completed that speed test?
26-08-2019 7:44 PM
27-08-2019 9:11 AM
- « Previous
- Next »
