gea test to see how things are going
Fixes: 1,602
Re: gea test to see how things are going
We run something called KBD (Knowledge Based Diagnostics) which includes a variety of tests. The tests that are most relevant to the issue you're experiencing are GEA Service Detail, BRAG History and VLAN Analysis:
GEA Test Detail
Circuit ID: N/A Service ID: [Redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 75.8 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Target Fix Time
Fault Report Advised N
Estimated Line Length In Metres 367.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-02-19T15:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 74.1 Mbps 75.8 Mbps 75.2 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 693.0 Sec 900.0 Sec 899.2 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-03-04T14:49:59.074+00:00 2019-03-04T15:04:59.074+00:00
Ingress Code Violation 0 125
Egress Code Violation 0 0
Errored Seconds 3 2
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
BRAG History
Service Layer Data
Telephone Number: N/A Test Executed On: 2019-03-04T15:08:10.411Z
Date BRAG Brandenburg Code
Line Reach Rate Line Stability
03-03-2019 Very Good Good OK
02-03-2019 Very Good Good OK
01-03-2019 Very Good Good OK
28-02-2019 Very Good Excellent OK
27-02-2019 Very Good Very Good OK
26-02-2019 Very Good Very Good OK
25-02-2019 Very Good Very Good OK
24-02-2019 NA NA NA
23-02-2019 Very Good Bad OK
22-02-2019 Very Good Bad OK
21-02-2019 Very Good Bad OK
20-02-2019 Very Good Bad OK
19-02-2019 Very Good Very Bad OK_DT
18-02-2019 Very Good Very Bad OK_DT
17-02-2019 Good Bad OK_DT
16-02-2019 Good Bad OK
15-02-2019 Good Bad OK
14-02-2019 Good Bad OK
13-02-2019 Very Good Good OK
12-02-2019 Very Good Good OK
11-02-2019 Very Good Good OK
10-02-2019 Very Good Good OK
09-02-2019 NA NA NA
08-02-2019 Very Good Good OK
07-02-2019 Very Good Good OK
06-02-2019 Very Good Bad OK
05-02-2019 NA NA NA
04-02-2019 Very Good Bad OK
VLAN Analysis
VLAN ID: [Redacted] Test Executed On: 2019-03-04T15:09:25.539Z
Date HOT VLAN(Yes/No) Action Fix Date
04-03-2019 NO
03-03-2019 NO
02-03-2019 NO
01-03-2019 NO
28-02-2019 NO
27-02-2019 NO
26-02-2019 NO
Fixes: 1,602
Hi @iangilf
I understand you've PM'd @JonoH regarding this and advised that you're experiencing disconnections too.
Do you see more drops than indicated below?
If you do then the next step would be to arrange another engineer to investigate further and I'd recommend raising a fault to us at http://faults.plus.net letting us know over here once you've completed it.
iangilf
yes there has been and yes please arrange engineer ...AM morning  please as im on nights thankyou very much
TheMightyAJ
Fixes: 126
Hi @iangilf,
As the drops are more frequent than we're seeing I've raised a ticket on your account concerning this which can be viewed here. Please let us know once you've updated the ticket so that we can progress the investigation of your fault as soon as possible.
 Alex H
iangilf
yep done thanks
OskarPapa
Fixes: 65
Thanks for that @iangilf.
You'll receive notification shortly via your ongoing ticket, but just an FYI that we've now booked in an engineer appt. for Wednesday 6th March between 8am and 1pm.
Please let us know if you need anything else in the meantime.
iangilf
ok thanks very much
iangilf
hi just to let you know the engineer has been he was a top bloke he actually listened to me and we talked of what had been going on he made some changes to the line and he rewired inside the cab ...
he did lift and shift and my stats are
6. Data rate: 20000 / 73792
7. Maximum data rate: 31152 / 86686
8. Noise margin: 12.8 / 6.4
9. Line attenuation: 17.1 / 14.3
10. Signal attenuation: 16.9 / 14.3
he said at this  max attainable data rate i should be seeing the full 80 meg but he also said that plusnet might have a different profile set up on plusnets system ....he also said give it ten days to settle but what were saying if the profile is setup wrong at plusnets side it wont go any higher so can u please identify why it doesnt get above this sync rate its showing please and also when you are able to can you post an upto date GEA test please thankyou
kind regards
ian
OskarPapa
Fixes: 65
Hi @iangilf , thanks for your post.
On running a GEA, everything is looking set up correctly. We can see below that we're showing you as in sync at 73.8mbps, on the correct 80/20 profile. That being said, we can see that the max rate seems to be hovering around 73.7:
GEA Test Detail
Circuit ID <REDACTED FOR SECURITY> Service ID <REDACTED FOR SECURITY>
Test Outcome Pass
Sync Status In Sync
Downstream Speed 73.8 Mbps
Estimated Line Length In Metres 401.1
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-03-06T10:30:00
Down Stream Line Rate 73.7 Mbps 73.7 Mbps 73.7 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Start Time Stamp 2019-03-06T15:20:02.832+00:00 2019-03-06T15:35:02.832+00:00
Ingress Code Violation 0 0
Errored Seconds 0 0
I've also checked the connection profiles our side and ensured that the correct 80mbps profile is in effect.
As everything's set up correctly and you're receiving speeds well in excess of the minimum line estimates (63.1mbps - 80mbps), there isn't a great deal we're going to be able to do to increase the useable speed you're seeing.
Please let us know if you need any further assistance at all.
iangilf
Well in that case as thus was a fault can u request a remote dlm reset please as I shouldn't have interleaved on either as we are gamers her and the ping rates are higher than before so if u can request a remote dlm reset please I would appreciate that
Fixes: 1,602
I'm afraid that as your line isn't banded we can't request a DLM reset as it would be rejected. The trial where we request DLM rests is purely designed to remove banding remotely off a line as opposed to adding or removing other configurations.
iangilf
I thought u could request it after a fault ?
ejs
Aspiring Hero
Fixes: 25
It's probably on interleaving right now because it's just been reset! I think all FTTC lines are initially on interleaving, when new or when the DLM gets reset. The interleaving will probably be removed by the DLM after a few days.
Also, when on interleaving, the max attainable rate reported by the modem tends to be somewhat higher than what you can actually get. I think it might just reach the full 80Mb, or perhaps it will be a couple of Mb under.
iangilf
ok mate ta i will wait n see then cheers
iangilf
an update the engineer contacted me today to see how it was going i said it was ok i then went on to ask him to do a full dlm reset on my line and remove the interleaving he did this for me and now my stats are
0 Days, 0 Hours 1 Minutes 27 Seconds
20.00 Mbps / 79.99 Mbps
32771 / 82790
13.2 dB / 6.7 dB
14.1 dB
so i dont care what u say about resetting dlm doesnt help anyone it obviously does or my stats wouldnt have increased to back to perfect again
i dont know why u dont arrange with openreach to do dlms in the first place it would save so much time and frustration
anyways im happy now ....what an excellent engineer he is shame they all aint like that
