gea test to see how things are going
- gea test to see how things are going
Re: gea test to see how things are going
25-02-2019 5:39 PM - edited 25-02-2019 7:55 PM
full gea test please ty
25-02-2019 9:34 PM
Hello @iangilf,
Thanks for getting in touch, below is the requested GEA test. Please get back to us if you need any further assistance.
GTC_FTTC_SERVICE_0000 | |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 75.2 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 339.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Regular Interference Observed on Week Days |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From 14:30 to 14:45 |
Interference Location | Unknown |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-02-12T21:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 71.3 Mbps | 75.9 Mbps | 74.8 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 110.0 Sec | 900.0 Sec | 897.0 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-25T21:04:54.371+00:00 | 2019-02-25T21:19:54.371+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 2 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
25-02-2019 9:45 PM
thanks
27-02-2019 9:49 AM
27-02-2019 12:41 PM
27-02-2019 12:46 PM
27-02-2019 2:18 PM
Thanks for getting back to me so quickly @iangilf.
As per your ticket instruction - I've removed the component from our side and so a quick reboot of your router should finalise the removal.
Please let me know if you need any further assistance.
28-02-2019 5:17 AM
hi this is very frustrating .....why has my throuput dropped again back down to 68 meg dead on
can u give my line another kick and increase what u need to why do i have to ask virtually every week for this to be done its very frustrating
1. Product name: | Plusnet Hub |
2. Serial number: | +081441+NQ54605283 |
3. Firmware version: | Software version 4.7.5.1.83.8.259 Last updated 19/07/18 |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 0 days, 06:40:23 |
6. Data rate: | 20000 / 75050 |
7. Maximum data rate: | 28055 / 75950 |
8. Noise margin: | 9.8 / 6.2 |
9. Line attenuation: | 18.8 / 13.8 |
10. Signal attenuation: | 18.7 / 13.8 |
11. Data sent/received: | 174.0 MB / 8.2 GB |
28-02-2019 12:17 PM
Hi @iangilf,
I've tested your line today and upon review I'm unable to find any faults with the service. Though I appreciate that it isn't the very highest that the line is able to provide, the throughput speed that you're reporting is well within the estimated speed range for your line and as this is the case I'm afraid there isn't anything that we can do to increase the speeds from our end of things.
28-02-2019 12:58 PM
28-02-2019 4:38 PM
and yet no reply i will be putting in a massive complaint in regards to this issue you dont seem to care all you say theres no problem when there is and that im syncing withing the speeds you cant do anything well i beg to differ you adjusted the line before which fixed this issue but now my ip profile has reverted back to how it always does 68 meg throuput
i will be writing email to the ceo and then go from there showing all these messages from this forum to them from when i first joined plusnet and all threw the time of being with you ive experienced problems over and over
28-02-2019 6:34 PM
Hello @iangilf,
I am sorry to hear you feel that why and can assure you we are only trying to help. The issue is all the test results are not indicating to what could be causing the problem you are experiencing at your side.
What we can see is that there is data being transferred continuously, can you make sure all devices are removed from your connection/wifi before running a speed test again, and let us know how you get on.
on 04-03-2019 2:38 PM - last edited on 04-03-2019 5:18 PM by Strat
04-03-2019 3:10 PM
Thanks for the detail.
Unfortunately there isn't anything more we can suggest as line tests aren't showing any issues. It's normal for your throughput to be lower than your sync rate due to the overheads of your connection.
04-03-2019 3:37 PM
not 10 megs in throughput there isnt ....what actual tests do u actually run on the line ? what is it u actually do i would like to know this please
