gea test to see how things are going
- Re: gea test to see how things are going
12-12-2018 6:26 PM
thanks and ok i have read the post and have replied myself thanks A.J
12-12-2018 7:09 PM
07-01-2019 5:31 PM
hi can u nudge my line up please since paying for a static ip address the threwput has gone down to in the 60s so can u possibly nudge this up for me please thanyou other than that the line has been performing ok
07-01-2019 5:52 PM
09-01-2019 4:58 PM
anyone know why my snr goes as low as it does when normally it sits at 6.3
5. DSL uptime: | 0 days, 07:19:30 |
6. Data rate: | 20000 / 77946 |
7. Maximum data rate: | 26889 / 76721 |
8. Noise margin: | 9.0 / 5.6 |
9. Line attenuation: | 17.0 / 14.0 |
10. Signal attenuation: | 16.9 / 14.0 |
11. Data sent/received: | 224.8 MB / 6.5 GB |
09-01-2019 5:29 PM
09-01-2019 6:18 PM
nope none for now just wondered why it was going so low as it didnt normaly
09-01-2019 6:21 PM
09-01-2019 6:30 PM
does the static ip effect any threwput issues or maximum speeds as i have seen this before on these forums if so can this be adjusted to the maximum plusnet offer please thanks
09-01-2019 6:34 PM
A static IP will only affect your throughput if the connection profile on your account is set lower than your IP profile. I can see the connection profile is already set at the maximum of 78mbps.
09-01-2019 6:42 PM
ok so what threwput should that give over a wired connection and also why isnt it set to 80 meg threwput?
cheers mate
09-01-2019 6:45 PM
13-01-2019 9:15 AM
my threwput turned to [-Censored-] again can u match my profile to my sync speed please as it cant be right
always happens and even more so on static ip why cant profiles be locked so they dont change shouldnt have to ask for threwput to be matched to sync rate my threwput is 68 i usually get 74 can u sort this please
5. DSL uptime: | 0 days, 00:17:53 |
6. Data rate: | 20000 / 77938 |
7. Maximum data rate: | 28522 / 78283 |
8. Noise margin: | 9.9 / 6.1 |
9. Line attenuation: | 18.9 / 13.7 |
10. Signal attenuation: | 18.7 / 13.7 |
13-01-2019 11:24 AM
also can i have a upto date gea test please thanks
14-01-2019 8:32 AM
Sorry to hear this. Do you mind me asking if you're actually experience any performance issues apart from the very small decrease in speed you're seeing?
With regards to the connection profile on your account this is set correctly for your sync rate.
As requested, here is a copy of our testing:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 74.2 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 339.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Regular Interference Observed on Weekends |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From 22:15 to 22:30 |
Interference Location | Unknown |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-01-01T08:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 73.7 Mbps | 78.2 Mbps | 75.1 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 678.0 Sec | 900.0 Sec | 898.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-01-14T08:04:25.532+00:00 | 2019-01-14T08:19:25.532+00:00 |
Ingress Code Violation | 0 | 74 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 4 | 2 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
