fibre down
- fibre down
- « Previous
- Next »
Re: fibre down
11-01-2016 5:31 PM
http://www.increasebroadbandspeed.co.uk/g.inp ( Is this also refering to both types of cabs or just Huawei (Wah-Way) and only via a Billion.
Re: fibre down
11-01-2016 9:15 PM
Quote Openreach G.INP Briefing to ISPs
* Retransmission can operate in both downstream and upstream channels simultaneously, although ECI equipment (either modems or DSLAMS) doesn’t currently support upstream retransmission.
The 2nd article could be misleading. Those Billions aren't the only vDSL compatible modem/routers that are G.INP compatible on downstream and upstream. However, like the ECI modems, the BT HH5A and the Plusnet Hub One (a re-badged HH5A with some BT things removed) are only G.INP compatible on the downstream. The HH5B is compatible on the downstream and upstream. There are others.
You should be able to tell from your stats that it's enabled, but that speed improvement you got I guess is conclusive.
Re: fibre down
13-01-2016 10:40 PM
Re: fibre down
14-01-2016 12:13 AM
all other manual adjustable digital clocks would blink 00:00 in their display, like on my oven tonight and I have to manually reset it. Most clocks now immediatlety reset on tv boxes leaving you unaware there even was a power outage.
Just checked router after outage I have internet connection at the moment.
Re: fibre down
14-01-2016 1:13 PM
Re: fibre down
15-01-2016 3:25 AM
Re: fibre down
02-02-2016 7:07 PM
A surge protector has been removed from any new VDSL master sockets that are fitted for FTTC users and is supposed to help.
The wall socket lead end could be fitted with a rj45 not rj11 and also be a twisted pair data cable, is this worth doing over the cheap flat provided.
Re: fibre down
02-02-2016 7:12 PM
I use one of these just for peace of mind than anything else:
http://www.tandyonline.co.uk/electronics/telecoms-dsl/high-speed-rj11-dsl-cable-1m.html
They do different lengths as well.
Re: fibre down
02-02-2016 7:20 PM
Re: fibre down
02-02-2016 7:49 PM
Re: fibre down
03-02-2016 2:24 AM
- « Previous
- Next »
