Hub One DMZ
nickjbyrne
Hub One DMZ
I've put a box in the Hub One DMZ, i can only connect to it over ssh either internally or externally but from a single host. I've tried several others and it just wont allow inbound connections. I'm wondering if anyone else uses this feature or do they just port map instead? I'm on firmware version 4.7.5.1.83.8.217 Last updated 02/02/16
