fibre down
- fibre down
Re: fibre down
29-11-2015 5:15 PM
Re: fibre down
29-11-2015 6:07 PM
Re: fibre down
29-11-2015 6:39 PM
Re: fibre down
29-11-2015 7:01 PM
Re: fibre down
29-11-2015 7:45 PM
Re: fibre down
30-11-2015 10:57 AM
Contact Plusnet and ask them to kill any stale session(s) that exist.
Re: fibre down
30-11-2015 1:27 PM
Re: fibre down
30-11-2015 1:31 PM
Edit: Maybe that's what you meant by reply #184 which I interpreted as meaning switching the modem off.
Re: fibre down
02-12-2015 7:08 PM
I just wonder if it was that affecting me also but if it was then a neighbour could have sorted the rest of us out, ringing plusnet now to see what i do because i currently have an engineer for me tomorrow morning booked
Re: fibre down
02-12-2015 7:51 PM
Re: fibre down
02-12-2015 8:00 PM
Re: fibre down
02-12-2015 8:11 PM
Re: fibre down
02-12-2015 11:26 PM
Re: fibre down
05-01-2016 12:24 AM
There seems to be 3 places where you can tinker and add them.
On quickstart set up the dns servers automatically come up as Plusnets in the Billion. Even though TR069 client is off by default in Billion. Is this normal Anotherone.
First click (after login) on Configuration and you can type em there and apply them in LAN (I haven 't done so here). There's also a Use Routers Settings as DNS Server with ticked box option.
Then after clicking WAN its shows both ATM Interface where it seems you can edit and apply. Also PTM Interface below edit and apply. (Also get an error message quite often after clicking edit option here.
My iMac Network settings show the router DNS server with the Billion router without me inputing them in imac settings. Old Netgear router didn't show the change like the Billion.
http://www.increasebroadbandspeed.co.uk/uk-isp-dns-server-settings
The recommended google DNS given does it matter which goes as primary.
Re: fibre down
05-01-2016 7:00 AM
You can use whichever DNS you choose, whether set in a router or on a client device. For Google, 8.8.8.8 is often used as the primary (maybe it has more capacity?) but at the end of the day set whichever you find give you the best responses. They needn't be from the same source either, you can use a mixture eg. one google, one Plusnet.
If you haven't sussed how to change them on the Billion 8800NL, I'm sure someone who has one can advise.
