VPN access errors
- Re: VPN access errors
VPN access errors
26-03-2020 8:22 PM
For the last few years I've had no problems with using VPN via my PlusNet router, but since this Covid19 kicked off, a lot more people are working from home and I'm getting VPN capacity errors. Is anyone else getting the same problem? I can't effectively work from home if this issue persists.
27-03-2020 12:26 PM
What VPN are you using? It is more likely to be a capacity problem at the far end than with Plusnet.
27-03-2020 1:14 PM
27-03-2020 1:22 PM
Well a VPN should be prioritised above Netflix. What errors are you seeing? Is it unable to connect, or does it drop a lot, or just slow? Are there more people from your business working from home than usual? Some small company VPN devices support a relatively small number of concurrent VPNs, and that may where your problem is (e.g. my Draytek only supports a max of 32 incoming VPN connections).
27-03-2020 3:19 PM
