VPN access errors
VPN access errors
For the last few years I've had no problems with using VPN via my PlusNet router, but since this Covid19 kicked off, a lot more people are working from home and I'm getting VPN capacity errors. Is anyone else getting the same problem? I can't effectively work from home if this issue persists.
4 REPLIES 4
Seasoned Pro
Re: VPN access errors
What VPN are you using? It is more likely to be a capacity problem at the far end than with Plusnet.
I’m not sure of the type of VPN per se, as I’m just using the standard VPN our business has always supplied. I think it’s defo a capacity problem somewhere, with so many people working from home or streaming Netflix!
Seasoned Pro
Well a VPN should be prioritised above Netflix. What errors are you seeing? Is it unable to connect, or does it drop a lot, or just slow? Are there more people from your business working from home than usual? Some small company VPN devices support a relatively small number of concurrent VPNs, and that may where your problem is (e.g. my Draytek only supports a max of 32 incoming VPN connections).
Interesting, we’re using Draytek, and there’s certainly a lot more people working from home. I’ll ask our IT support what our limit is. Thanks Smiley
