Sync rate suddenly dropped from 74 to 61 last night
brookheather
Hi - can a PlusNet staff member please run a check on my line as my router re-synced last night and the sync rate suddenly dropped from 74 to 61 Mbps - the upstream was at the max of 19999 on fastpath and has been free of errors but that is now slightly lower and is now interleaved resulting in higher ping.  I have tried re-syncing the router but the sync rate is still stuck well below estimate for my line.
BT FTTP 500 + pfSense + Uniquiti Unifi 6 Pro
14 REPLIES 14
MatthewWheeler
Fixes: 480
Re: Sync rate suddenly dropped from 74 to 61 last night
Sorry to hear your speeds have dropped.
Our tests aren't showing any obvious cause so I'd recommend raising a fault here so that our Faults team can investigate further.
 Matthew Wheeler
brookheather
Thanks I have raised a fault for this.  I tried rebooting this morning and it is still stuck at 61Mbps.
Chris
Legend
Fixes: 169
It looks like you had quite a few disconnections on Saturday evening which is the likely cause of the speed drop:
The speed should increase on it's own over time however I'll get the fault reported to Openreach too.
The profile is still open, so there's no issue with that:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 62.7 Mbps
Upstream Speed 19.9 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 253.1
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-07-05T13:30:00
brookheather
Thanks - I was trying to get a Netgear DM200 VDSL router working on Saturday night but after two hours and several factory resets I failed to get it to connect to PlusNet so gave up and went back to using my Asus DSL-AC68U instead.  So the disconnections were just me resetting the router so I guess I'll just leave it alone and hopefully it will go back to normal.  Annoying that you can't try out different routers without DLM intervening!
Chris
Legend
Fixes: 169
You should be able to, but rather than just powering the router of each time you'd be best placed to log in to the router and press disconnect. This tells the DLM it's a soft disconnection and won't be regarded as a fault.
brookheather
Do you mean disconnect the PPoE session?  I'm not sure how you would disconnect the DSL connection?  Does the DLM see the PPoE session and so knows if it has been disconnected first?  I wasn't able to make a connection to PlusNet so no PPoE session - hence the factory resets.
Chris
Legend
Fixes: 169
The PPPoE session. Once that's ended you should be ok to power off the router.
brookheather
Today my router has re-synced with G.INP enabled and FastPath on both up and downstream and the sync rate is back to normal 74Mbps so no need for an engineer visit now.
brookheather
@Chris - can you please nudge my current line speed back up to 74 Mbps please as it is stuck on 59 Mbps.
Chris
Legend
Fixes: 169
Profile on our side is reset now.
brookheather
After exactly 24 hours of running fine on FastPath the router has re-synced and dropped the speed back down to 61Mbps again with interleaving?  I had no CRC errors over the past 24 hours so don't understand what is going on with my line...
SNR
5.3 dB
7.5 dB
Line Attenuation
5.7 dB
10.6 dB
Path Mode
Interleaved
Interleaved
Interleave Depth
2789
607
Data Rate
61151 kbps
19998 kbps
MAX Rate
101012 kbps
28710 kbps
Chris
Legend
Fixes: 169
It's likely that something is causing intermittent noise or interference on your line. Is your phone line clear with no noise or crackling?
brookheather
OR engineer visited this morning and spent a couple of hours moving my connection to different equipment within the same cabinet.  My connection is now back on FastPath so will monitor it to see if it stays or whether interleaving or G.INP gets enabled.  My downstream is back to near normal though probably lower than it could be given the current SNR margin - it may increase when the DLM next re-syncs my line:
DSL modulation
ITU G.993.2(VDSL2)
SNR
6.8 dB
7.4 dB
Line Attenuation
5.6 dB
10.6 dB
Path Mode
FastPath
FastPath
Interleave Depth
1
1
Data Rate
72757 kbps
19999 kbps
MAX Rate
90136 kbps
23325 kbps
POWER
12.5 dbm
-4.5 dbm
INP
0.7 symbols
1.0 symbols
Fixes: 1,601
Let us know how the monitoring goes.
