Openreach make change G.INP & IP Profile on huawei cabinet
- Openreach make change G.INP & IP Profile on huawei...
11-11-2017 7:15 PM
I was shocked to see Openreach engineer working on my FTTC cabinet and then few hours later, my broadband went down for two hours and come back online. I was checked the modem stats and can't believe that openreach has adjusted G.INP on the cabinet. It's used to be G.INP on downstream of interleave depth 16 and fast path on upstream with no interleave. But, now it set G.INP enabled on both downstream and upstream of interleave depth 8 on both. Also openreach has make change to reduced IP Profile set at 74.1Mb as it used to be 77.35Mb. What is going on?
My sync rate was the same as before and now on 79999K/20000K.
Re: Openreach make change G.INP & IP Profile on huawei cabinet
11-11-2017 7:43 PM
G.INP on on the upstream ? hmmm
11-11-2017 8:39 PM - edited 11-11-2017 10:55 PM
Updated on GEA Test Result sent from Plusnet. It's appear that Plusnet Hub One has ruined it to kick in DLM against it after Hub One has rebooted it few times to updated the software version. So, I went back to Billion 8800NL router.
12-11-2017 5:48 PM
Very angry now Something going on with the cabinet. Another DLM again after resync after stable connection for 23 hours with Billion router. I am fed up with this. What is caused this? The BT IP Profile now drop to 68.5 Mb from 74.1Mb. Really peed me off. The DLM love to lower my speed what a disgrace BT DLM system shouldn't be placed for fibre.
Going to ask Plusnet to get it DLM reset or I will cancel the fibre broadband for good. Not paying for 68Meg as I am paying for 76Meg.
12-11-2017 6:02 PM
I have now raised the fault on the ticket.
12-11-2017 7:01 PM
Your snr is jumping all over the place.
Can you click on the "Telnet Data/Connection Stats" Tab, then click the notepad at the bottom of the page come back here click the code button and paste the text for me @goldenfibre
12-11-2017 7:09 PM
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 1 Last initialization procedure status: 0 Max: Upstream rate = 32812 Kbps, Downstream rate = 90326 Kbps Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 73998 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 10.1 14.0 Attn(dB): 11.5 0.0 Pwr(dBm): 12.5 -0.6 VDSL2 framing Bearer 0 MSGc: -6 -6 B: 146 81 M: 1 1 T: 0 0 R: 8 8 S: 0.0630 0.1295 L: 19683 5560 D: 8 4 I: 155 90 N: 155 90 Q: 8 4 V: 4 1 RxQueue: 140 135 TxQueue: 35 27 G.INP Framing: 18 18 G.INP lookback: 31 27 RRC bits: 24 24 Bearer 1 MSGc: 154 58 B: 0 0 M: 2 2 T: 2 2 R: 16 16 S: 6.4000 16.0000 L: 40 16 D: 3 1 I: 32 32 N: 32 32 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 0 OHFErr: 0 0 RS: 483582680 4281413 RSCorr: 37 85 RSUnCorr: 0 0 Bearer 1 OHF: 476077 477955 OHFErr: 0 0 RS: 4760155 1911823 RSCorr: 0 1 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 105551 81 rtx_c: 21 165 rtx_uc: 73736 25526 G.INP Counters LEFTRS: 10 10 minEFTR: 73985 19997 errFreeBits: 214819084 32392908 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 1088203191 0 Data Cells: 10447612 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 11 0 SES: 11 0 UAS: 64 53 AS: 7648 Bearer 0 INP: 52.00 55.00 INPRein: 1.00 1.00 delay: 0 0 PER: 0.00 0.00 OR: 0.01 0.01 AgR: 74377.87 20184.26 Bearer 1 INP: 4.50 4.00 INPRein: 4.50 4.00 delay: 3 0 PER: 16.06 16.06 OR: 79.68 31.87 AgR: 79.68 31.87 Bitswap: 3/3 2/2 Total time = 1 days 1 hours 37 min 7 sec FEC: 5631 961 CRC: 562 0 ES: 11 0 SES: 11 0 UAS: 64 53 LOS: 1 0 LOF: 8 0 LOM: 0 0 Latest 15 minutes time = 7 min 7 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 1 hours 37 min 7 sec FEC: 4 6 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 5627 955 CRC: 562 0 ES: 11 0 SES: 11 0 UAS: 64 53 LOS: 1 0 LOF: 8 0 LOM: 0 0 Since Link time = 2 hours 7 min 27 sec FEC: 37 85 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
12-11-2017 8:47 PM - edited 13-11-2017 10:04 AM
Latest of mydslwebstats for SNR from overnight while it running in the background with up to date as of today at 10am. It's will help Plusnet fault team to look at it.
13-11-2017 12:05 AM
There is possible for the line are banded by DLM at sync rate 73998kbps instead of 79999kbps.
13-11-2017 12:31 AM
Also posted here on Kitz.
13-11-2017 12:40 AM - edited 13-11-2017 10:01 AM
Latest connection stats as of 10am today:
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 1 Last initialization procedure status: 0 Max: Upstream rate = 32945 Kbps, Downstream rate = 90668 Kbps Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 73998 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 10.1 14.2 Attn(dB): 11.5 0.0 Pwr(dBm): 12.5 -0.7 VDSL2 framing Bearer 0 MSGc: -6 -6 B: 146 81 M: 1 1 T: 0 0 R: 8 8 S: 0.0630 0.1295 L: 19683 5560 D: 8 4 I: 155 90 N: 155 90 Q: 8 4 V: 4 1 RxQueue: 140 135 TxQueue: 35 27 G.INP Framing: 18 18 G.INP lookback: 31 27 RRC bits: 24 24 Bearer 1 MSGc: 154 58 B: 0 0 M: 2 2 T: 2 2 R: 16 16 S: 6.4000 16.0000 L: 40 16 D: 3 1 I: 32 32 N: 32 32 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 0 OHFErr: 0 0 RS: 3868471680 4086278 RSCorr: 310 854 RSUnCorr: 0 0 Bearer 1 OHF: 3807999 677716 OHFErr: 0 0 RS: 38079377 2408876 RSCorr: 0 6 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 105571 217 rtx_c: 41 301 rtx_uc: 73736 25526 G.INP Counters LEFTRS: 10 10 minEFTR: 74004 20000 errFreeBits: 275240413 48716194 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 114268075 0 Data Cells: 35726443 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 11 0 SES: 11 0 UAS: 64 53 AS: 61176 Bearer 0 INP: 52.00 55.00 INPRein: 1.00 1.00 delay: 0 0 PER: 0.00 0.00 OR: 0.01 0.01 AgR: 74377.87 20184.26 Bearer 1 INP: 4.50 4.00 INPRein: 4.50 4.00 delay: 3 0 PER: 16.06 16.06 OR: 79.68 31.87 AgR: 79.68 31.87 Bitswap: 4/4 107/107 Total time = 1 days 16 hours 29 min 15 sec FEC: 5904 1730 CRC: 562 0 ES: 11 0 SES: 11 0 UAS: 64 53 LOS: 1 0 LOF: 8 0 LOM: 0 0 Latest 15 minutes time = 14 min 15 sec FEC: 24 11 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 3 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 16 hours 29 min 15 sec FEC: 277 775 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 5627 955 CRC: 562 0 ES: 11 0 SES: 11 0 UAS: 64 53 LOS: 1 0 LOF: 8 0 LOM: 0 0 Since Link time = 16 hours 59 min 35 sec FEC: 310 854 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
13-11-2017 2:09 PM
Updated on fibre stats
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 1 Last initialization procedure status: 0 Max: Upstream rate = 32903 Kbps, Downstream rate = 90435 Kbps Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 73998 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 10.1 14.2 Attn(dB): 11.5 0.0 Pwr(dBm): 12.5 -0.7 VDSL2 framing Bearer 0 MSGc: -6 -6 B: 146 81 M: 1 1 T: 0 0 R: 8 8 S: 0.0630 0.1295 L: 19683 5560 D: 8 4 I: 155 90 N: 155 90 Q: 8 4 V: 4 1 RxQueue: 140 135 TxQueue: 35 27 G.INP Framing: 18 18 G.INP lookback: 31 27 RRC bits: 24 24 Bearer 1 MSGc: 154 58 B: 0 0 M: 2 2 T: 2 2 R: 16 16 S: 6.4000 16.0000 L: 40 16 D: 3 1 I: 32 32 N: 32 32 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 0 OHFErr: 0 0 RS: 514612168 4205769 RSCorr: 339 891 RSUnCorr: 0 0 Bearer 1 OHF: 4734381 559277 OHFErr: 0 0 RS: 47343190 1834456 RSCorr: 0 7 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 105571 221 rtx_c: 41 305 rtx_uc: 73736 25526 G.INP Counters LEFTRS: 10 10 minEFTR: 73985 20000 errFreeBits: 292039485 53254289 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 2231760445 0 Data Cells: 40038255 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 11 0 SES: 11 0 UAS: 64 53 AS: 76058 Bearer 0 INP: 52.00 55.00 INPRein: 1.00 1.00 delay: 0 0 PER: 0.00 0.00 OR: 0.01 0.01 AgR: 74377.87 20184.26 Bearer 1 INP: 4.50 4.00 INPRein: 4.50 4.00 delay: 3 0 PER: 16.06 16.06 OR: 79.68 31.87 AgR: 79.68 31.87 Bitswap: 5/5 120/120 Total time = 1 days 20 hours 37 min 17 sec FEC: 5933 1767 CRC: 562 0 ES: 11 0 SES: 11 0 UAS: 64 53 LOS: 1 0 LOF: 8 0 LOM: 0 0 Latest 15 minutes time = 7 min 17 sec FEC: 0 9 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 20 hours 37 min 17 sec FEC: 306 812 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 5627 955 CRC: 562 0 ES: 11 0 SES: 11 0 UAS: 64 53 LOS: 1 0 LOF: 8 0 LOM: 0 0 Since Link time = 21 hours 7 min 37 sec FEC: 339 891 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
13-11-2017 3:25 PM
Hi there.
It doesn't look like your service is banded:
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Your modem's sync rate has dropped:
Sync Status | In Sync |
Downstream Speed | 70.8 Mbps |
Upstream Speed | 19.1 Mbps |
As it's within your estimates, it's unlikely an engineer will investigate this I'm afraid.
13-11-2017 4:12 PM - edited 13-11-2017 4:17 PM
@Gandalf No, my line was sync rate at 79999k since 2014, DLM take action. I am not very happy about BT DLM decide to reduced to 73998k as this is NOT the service I sign up.
BT Estimated my line is 80Meg.
Can you please send me another GEA Test and post here please.
Where did it stated from?
My modem on Billion didn't say it.
Max: Upstream rate = 32899 Kbps, Downstream rate = 90668 Kbps Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 73998 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 10.1 14.2 Attn(dB): 11.5 0.0 Pwr(dBm): 12.5 -0.7
13-11-2017 4:26 PM
We've seen it before on "Retransmission High" profiles, the "Downstream Speed" reported by the GEA Test is lower than the "sync speed" reported by the modem. Probably the details given in the "Profile Name" field are outdated.
