Openreach make change G.INP & IP Profile on huawei cabinet
goldenfibre
Seasoned Pro
Fixes: 12
I was shocked to see Openreach engineer working on my FTTC cabinet and then few hours later, my broadband went down for two hours and come back online. I was checked the modem stats and can't believe that openreach has adjusted G.INP on the cabinet. It's used to be G.INP on downstream of interleave depth 16 and fast path on upstream with no interleave. But, now it set G.INP enabled on both downstream and upstream of interleave depth 8 on both. Also openreach has make change to reduced IP Profile set at 74.1Mb as it used to be 77.35Mb. What is going on?
My sync rate was the same as before and now on 79999K/20000K.
G.INP statsG.INP statsG.INP data summaryG.INP data summaryBTw ip profile rateBTw ip profile rate
28 REPLIES 28
30FTTC06
Fixes: 4
Re: Openreach make change G.INP & IP Profile on huawei cabinet
G.INP on on the upstream ? hmmm
goldenfibre
Seasoned Pro
Fixes: 12
Updated on GEA Test Result sent from Plusnet. It's appear that Plusnet Hub One has ruined it to kick in DLM against it after Hub One has rebooted it few times to updated the software version. So, I went back to Billion 8800NL router. GEA Test resultGEA Test result
goldenfibre
Seasoned Pro
Fixes: 12
Very angry now Sad Sad Something going on with the cabinet. Another DLM again after resync after stable connection for 23 hours with Billion router. I am fed up with this. What is caused this? The BT IP Profile now drop to 68.5 Mb from 74.1Mb. Really peed me off. The DLM love to lower my speed what a disgrace BT DLM system shouldn't be placed for fibreG.INP statsG.INP statsG.INP data summaryG.INP data summaryBTw ip profile rateBTw ip profile rate.
Going to ask Plusnet to get it DLM reset or I will cancel the fibre broadband for good. Not paying for 68Meg as I am paying for 76Meg.
goldenfibre
Seasoned Pro
Fixes: 12
I have now raised the fault on the ticket.
30FTTC06
Fixes: 4
Your snr is jumping all over the place.
Can you click on the "Telnet Data/Connection Stats"  Tab, then click the notepad at the bottom of the page come back here click the code button and paste the text for me @goldenfibre
goldenfibre
Seasoned Pro
Fixes: 12
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    1
Last initialization procedure status:   0
Max:    Upstream rate = 32812 Kbps, Downstream rate = 90326 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 73998 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        10.1            14.0
Attn(dB):        11.5            0.0
Pwr(dBm):        12.5           -0.6
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              -6
B:              146             81
M:              1               1
T:              0               0
R:              8               8
S:              0.0630          0.1295
L:              19683           5560
D:              8               4
I:              155             90
N:              155             90
Q:              8               4
V:              4               1
RxQueue:                140             135
TxQueue:                35              27
G.INP Framing:          18              18
G.INP lookback:         31              27
RRC bits:               24              24
                        Bearer 1
MSGc:           154             58
B:              0               0
M:              2               2
T:              2               2
R:              16              16
S:              6.4000          16.0000
L:              40              16
D:              3               1
I:              32              32
N:              32              32
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               0
OHFErr:         0               0
RS:             483582680               4281413
RSCorr:         37              85
RSUnCorr:       0               0
                        Bearer 1
OHF:            476077          477955
OHFErr:         0               0
RS:             4760155         1911823
RSCorr:         0               1
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         105551          81
rtx_c:          21              165
rtx_uc:         73736           25526
                        G.INP Counters
LEFTRS:         10              10
minEFTR:        73985           19997
errFreeBits:    214819084               32392908
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    1088203191              0
Data Cells:     10447612                0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             11              0
SES:            11              0
UAS:            64              53
AS:             7648
                        Bearer 0
INP:            52.00           55.00
INPRein:        1.00            1.00
delay:          0               0
PER:            0.00            0.00
OR:             0.01            0.01
AgR:            74377.87        20184.26
                        Bearer 1
INP:            4.50            4.00
INPRein:        4.50            4.00
delay:          3               0
PER:            16.06           16.06
OR:             79.68           31.87
AgR:            79.68   31.87
Bitswap:        3/3             2/2
Total time = 1 days 1 hours 37 min 7 sec
FEC:            5631            961
CRC:            562             0
ES:             11              0
SES:            11              0
UAS:            64              53
LOS:            1               0
LOF:            8               0
LOM:            0               0
Latest 15 minutes time = 7 min 7 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 1 hours 37 min 7 sec
FEC:            4               6
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 1 day time = 24 hours 0 sec
FEC:            5627            955
CRC:            562             0
ES:             11              0
SES:            11              0
UAS:            64              53
LOS:            1               0
LOF:            8               0
LOM:            0               0
Since Link time = 2 hours 7 min 27 sec
FEC:            37              85
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
goldenfibre
Seasoned Pro
Fixes: 12
Latest of mydslwebstats for SNR from overnight while it running in the background with up to date as of today at 10am. It's will help Plusnet fault team to look at it. SNR checkSNR check
goldenfibre
Seasoned Pro
Fixes: 12
There is possible for the line are banded by DLM at sync rate 73998kbps instead of 79999kbps.
Browni
Aspiring Hero
Fixes: 60
Also posted here on Kitz.
goldenfibre
Seasoned Pro
Fixes: 12
Latest connection stats as of 10am today:
adsl info --stats
Status: Showtime
Max:    Upstream rate = 32945 Kbps, Downstream rate = 90668 Kbps
Mode:                   VDSL2 Annex B
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        10.1            14.2
Attn(dB):        11.5            0.0
Pwr(dBm):        12.5           -0.7
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              -6
B:              146             81
M:              1               1
T:              0               0
R:              8               8
S:              0.0630          0.1295
L:              19683           5560
D:              8               4
I:              155             90
N:              155             90
Q:              8               4
V:              4               1
RxQueue:                140             135
TxQueue:                35              27
RRC bits:               24              24
                        Bearer 1
MSGc:           154             58
B:              0               0
M:              2               2
T:              2               2
R:              16              16
S:              6.4000          16.0000
L:              40              16
D:              3               1
I:              32              32
N:              32              32
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               0
OHFErr:         0               0
RS:             3868471680              4086278
RSCorr:         310             854
RSUnCorr:       0               0
                        Bearer 1
OHF:            3807999         677716
OHFErr:         0               0
RS:             38079377                2408876
RSCorr:         0               6
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         105571          217
rtx_c:          41              301
rtx_uc:         73736           25526
                        G.INP Counters
LEFTRS:         10              10
minEFTR:        74004           20000
errFreeBits:    275240413               48716194
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    114268075               0
Data Cells:     35726443                0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             11              0
SES:            11              0
UAS:            64              53
AS:             61176
                        Bearer 0
INP:            52.00           55.00
INPRein:        1.00            1.00
delay:          0               0
PER:            0.00            0.00
OR:             0.01            0.01
                        Bearer 1
INP:            4.50            4.00
INPRein:        4.50            4.00
delay:          3               0
PER:            16.06           16.06
OR:             79.68           31.87
AgR:            79.68   31.87
Bitswap:        4/4             107/107
Total time = 1 days 16 hours 29 min 15 sec
FEC:            5904            1730
CRC:            562             0
ES:             11              0
SES:            11              0
UAS:            64              53
LOS:            1               0
LOF:            8               0
LOM:            0               0
Latest 15 minutes time = 14 min 15 sec
FEC:            24              11
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
FEC:            3               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 16 hours 29 min 15 sec
FEC:            277             775
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
FEC:            5627            955
CRC:            562             0
ES:             11              0
SES:            11              0
UAS:            64              53
LOS:            1               0
LOF:            8               0
LOM:            0               0
Since Link time = 16 hours 59 min 35 sec
FEC:            310             854
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
goldenfibre
Seasoned Pro
Fixes: 12
Updated on fibre stats
fibre full statsfibre full stats
adsl info --stats
Status: Showtime
Max:    Upstream rate = 32903 Kbps, Downstream rate = 90435 Kbps
Mode:                   VDSL2 Annex B
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        10.1            14.2
Attn(dB):        11.5            0.0
Pwr(dBm):        12.5           -0.7
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              -6
B:              146             81
M:              1               1
T:              0               0
R:              8               8
S:              0.0630          0.1295
L:              19683           5560
D:              8               4
I:              155             90
N:              155             90
Q:              8               4
V:              4               1
RxQueue:                140             135
TxQueue:                35              27
RRC bits:               24              24
                        Bearer 1
MSGc:           154             58
B:              0               0
M:              2               2
T:              2               2
R:              16              16
S:              6.4000          16.0000
L:              40              16
D:              3               1
I:              32              32
N:              32              32
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               0
OHFErr:         0               0
RS:             514612168               4205769
RSCorr:         339             891
RSUnCorr:       0               0
                        Bearer 1
OHF:            4734381         559277
OHFErr:         0               0
RS:             47343190                1834456
RSCorr:         0               7
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         105571          221
rtx_c:          41              305
rtx_uc:         73736           25526
                        G.INP Counters
LEFTRS:         10              10
minEFTR:        73985           20000
errFreeBits:    292039485               53254289
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    2231760445              0
Data Cells:     40038255                0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             11              0
SES:            11              0
UAS:            64              53
AS:             76058
                        Bearer 0
INP:            52.00           55.00
INPRein:        1.00            1.00
delay:          0               0
PER:            0.00            0.00
OR:             0.01            0.01
                        Bearer 1
INP:            4.50            4.00
INPRein:        4.50            4.00
delay:          3               0
PER:            16.06           16.06
OR:             79.68           31.87
AgR:            79.68   31.87
Bitswap:        5/5             120/120
Total time = 1 days 20 hours 37 min 17 sec
FEC:            5933            1767
CRC:            562             0
ES:             11              0
SES:            11              0
UAS:            64              53
LOS:            1               0
LOF:            8               0
LOM:            0               0
Latest 15 minutes time = 7 min 17 sec
FEC:            0               9
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 20 hours 37 min 17 sec
FEC:            306             812
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
FEC:            5627            955
CRC:            562             0
ES:             11              0
SES:            11              0
UAS:            64              53
LOS:            1               0
LOF:            8               0
LOM:            0               0
Since Link time = 21 hours 7 min 37 sec
FEC:            339             891
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Fixes: 1,600
Hi there.
It doesn't look like your service is banded:
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Your modem's sync rate has dropped:
Sync Status In Sync
Downstream Speed 70.8 Mbps
Upstream Speed 19.1 Mbps
As it's within your estimates, it's unlikely an engineer will investigate this I'm afraid.
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf No, my line was sync rate at 79999k since 2014, DLM take action. I am not very happy about BT DLM decide to reduced to 73998k as this is NOT the service I sign up.
BT Estimated my line is 80Meg.
Can you please send me another GEA Test and post here please.
Sync Status In Sync
Where did it stated from?
My modem on Billion didn't say it.
Max:    Upstream rate = 32899 Kbps, Downstream rate = 90668 Kbps
Mode:                   VDSL2 Annex B
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        10.1            14.2
Attn(dB):        11.5            0.0
Pwr(dBm):        12.5           -0.7
ejs
Aspiring Hero
Fixes: 25
We've seen it before on "Retransmission High" profiles, the "Downstream Speed" reported by the GEA Test is lower than the "sync speed" reported by the modem. Probably the details given in the "Profile Name" field are outdated.
