No DSL light on Openreach modem
soclanat
Recently moved house and was advised internet now up and running. It wasn't working and turned out there was a fault. Engineer was out to fix the fault yesterday and have been advised this is now complete. Problem is I still have no internet. The green DSL light on the modem is not on, and it never comes on or flashes at any point after turning on. I've replaced microfilter and cable today to try and eliminate that as a source of the problem... still nothing.
Is it possible to have my modem checked out remotely. I don't actually have a house phone to check if I'm getting a dial tone at all, although I've been told the line is fine.
Thanks.
6 REPLIES 6
Fixes: 1,600
Re: No DSL light on Openreach modem
Sorry to hear you're having connection issues following moving house.
Our tests aren't showing the cause for the problem so we'd likely need to arrange an engineer visit to further investigate this.
Before we go down that path can you confirm you've tried plugging your router into the test socket as explained Here? If you're still having issues connecting that way, I'd recommend reporting a broadband fault to us at http://faults.plus.net
Let us know how it goes.
soclanat
Thanks for the advice. I've removed the plate from the master socket and can see the removable section isn't wired at all. I have plugged into the test socket, but still nothing. I don't think this whole socket is wired correctly at all. I'll have a look at it myself tonight, but I don't really know what I'm doing.
Mustrum
Fixes: 77
Try plugging a phone into it, do you get dial tone? Does it give the correct number when you dial 17070?
Fixes: 1,600
No worries, I'd definitely try @Mustrum's suggestion to figure out if there is dial tone and if you've got the right number. This will determine if there's a crossed line and/or the phone line is faulty and will help us in choosing the right fault path when reporting this to our suppliers.
Regarding your master socket can you post up a photo?
soclanat
Problem solved.
After tracing the phone wiring into the house, I found another master socket hidden in the hall that works. It doesn't appear to be connected to the master socket in the living room or the other extension socket. Maybe those two are from an old second line.
Anyway, thanks for the advice. Helped me narrow down what the source of the problem could be.
EmilyD
Fixes: 117
Hi @soclanat,
Thank you for getting back in touch. I'm pleased to hear that you have found another master socket in the property and that your broadband is now up and running after connecting to that.
Please let us know whether there's anything else that you'd like to discuss.
 Emily D
