New fibre - slow downloads speeds
- Re: New fibre - slow downloads speeds
07-01-2015 8:32 AM
So I've just upgraded to the full fibre package, engineer installed yesterday and left me with speeds of 69 mbs download 16 upload in the morning all fine.
I noticed after 12pm speeds seems slower so have since done numerous speed tests and am consistently getting 4mps download and 11mbs upload - I thought your download was faster than the upload what gives any ideas? I've tried resetting the router, thanks in advance.
James
James
Message 1 of 5
(698 Views)
4 REPLIES 4
07-01-2015 9:11 AM
It's likely that the profile on our side needs a kick. I'll go and take a look now.
Message 2 of 5
(425 Views)
07-01-2015 9:17 AM
Ok thankyou will wait to hear from you
Regards
Regards
Message 3 of 5
(425 Views)
07-01-2015 9:17 AM
Yep, that's sorted now. If you don't see an improvement in speed then just log in to your router and press disconnect, wait a short while and press connect.
Message 4 of 5
(425 Views)
07-01-2015 10:32 AM
That's solved it - thankyou!
Message 5 of 5
(425 Views)
