Months of random dropouts with no apparent cause?
bobpullen
Fixes: 316
Re: A warning to all users, 'do you proud?' - No, lie, cheat and rip you off.
I pushed a router firmware update to your Hub One. This appears to address a particular observation where some devices on Huawei manufactured FTTC DSLAMs seem to perform below their ECI counterparts, particularly where the target downstream SNR of a line drops below 6dB. The actual cause is not fully understood and still under investigation, however altering some of the DSL layer logic in the router seems to be helping. We've been looking into this over recent weeks, rather than months.
jamessc
@bobpullen
Thanks, that's helpful
jamessc
@bobpullen Hi Bob, coudl you please supply another drop out chart? Many thanks
Kelly
Fixes: 9
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
That does look better!
Kelly Dorset
jamessc
Thanks Kelly. Yes, it is better, but still randomly dropping out for no apparent reason.
Kelly
Fixes: 9
Those might be profile changes. I  can't check myself, but someone tomorrow should be able to see.
Kelly Dorset
jamessc
Ok, not sure what a profile change is? thanks
Fixes: 1,601
A profile change would likely be referring to DLM doing its thing.
I've checked your connection and things seem stable for the past 3 days?
Have you noticed drops that we're not seeing?
jamessc
Hi Gandalf, no, but that's why I asked for a chart, the drop outs have previously happened at all hours so I wouldn't necessarily know about them. We'll have to keep watching for now. Thanks
Fixes: 1,601
No worries. Keep us posted.
jamessc
Hi Gandalf, could you please supply another drop-out chart for reference? Many thanks
Kelly
Fixes: 9
Kelly Dorset
Kelly
Fixes: 9
Do you feel like the line has become much more stable?
Kelly Dorset
jamessc
just had another drop out
