Hi, recently whilst using IP TV the channels don’t load. I’ve tried to check if it works on my phone using 4G and it does. Hence it means that my router willingly blocks the channel loading.
Im very happy with the fibre but if the IPTV keeps on being blocked by my routeur I will likely seek another fibre provider - could you please let me know if this issue can be solved ? Thanks
