Has my line been banded?
- Has my line been banded?
07-02-2026 1:27 AM
On FTTC, about 800m from the cabinet. Flaky connection issue recently resolved (Engineer traced the issue to a fault at the cabinet) , but now looks like my line is banded.
Stats from my router:
| Upstream | Downstream | |
| Current Rate (kbps) | 11175 | 39999 |
| Max Rate (kbps) | 11127 | 57159 |
| SNR Margin (dB) | 6.3 | 7.4 |
| Line Attenuation (dB) | 7.8 | 17.7 |
| Errors (pkts) | 5 | 0 |
The downstream sync is suspicious, compared to the max rate figure, isn't it? I also believe that the banding is indicated by the current rate showing a value ending in 999, AICBW (I frequently am...)
Thoughts welcome.
Re: Has my line been banded?
07-02-2026 8:02 AM
Yup, @Jaggies You have been banded, due to your earlier issues. Maybe asking PN to do a line reset will resolve it.
07-02-2026 10:26 PM
My first take here that you’ve been provisioned on 40/10 but the 11+ US somewhat refutes that.
AIUI getting a DLM reset on VDSL is not as easy as it used to be. You could be faced with waiting for automatic adjustment over three weeks.
08-02-2026 12:14 AM
If a staff member sees this, if possible, please see if you can get my line reset, otherwise I'll let nature take it's course.
08-02-2026 12:24 AM
Actually looks as though DLM may be working.
Stats look better, anyway...
| Current Rate (kbps) | 11283 | 44754 |
| Max Rate (kbps) | 11295 | 61187 |
| SNR Margin (dB) | 6.1 | 6.4 |
| Errors (pkts) | 62 | 27 |
